S10+ vs s10+ 5g battery life
clintw22
487
I'm thinking of upgrading from the note 9. I've searched on here and Google but didn't have much luck but can anyone help me decide which one to get for better battery life?
My opinion I think they be about same .
I have an S10+ 12G/1T and an S10 5G and I honestly cannot tell a difference in battery life. Caveat is that I am using both on 4G network, no 5G use. 5G would most likely impact the S10 5Gs usage.
Ya that's how I'd use mine. I'm in a small town and it's gonna be a few years before I actually got 5g here so it would be only 4g which I'd be fine with. But if the battery life is the same, no sense in spending extra money just for the bigger display. Thanks for the help guys!
Battery life is better on the 5G version I went from a Note 9 to the s10 5g and it's so much better. The 4500 battery on the s10 5g last me all day. The s10 is plus is 4100 so the difference isnt much.
Gasho
