A
I don't want to overcharge the phone when I go to bed, so a notification would help me.
What a wonderful saying. It never gets old.There is an app for that
https://play.google.com/store/apps/details?id=com.utopi.batterychargenotifier
You do NOT need an app.
Wait till your phone reaches 100% and you'll get a notification that your phone has been fully charged.
long press the notification and you'll see in there it says Popup notifications (should say silent) click that and pick a sound and you're done.
I used the Pokemon Center Healing sound whenever my phone charged to 100%
(I don't have the exact instructions on how to do it because my phone isn't at 100%, soon as i get the phone to 100% I will make the instructions more accurate)
OMGOSH I need to set the Pokémon Centre healing sound as my notification!!!! Thank you so much, that's genius!You do NOT need an app.
ok so I now have full instructions because my phone is fully charged.
Step 1 - when the full charged notification shows up press and hold it
Step 2 - press "details"
Step 3 - Touch where it says Battery Full Silent
Step 4 - Touch where it says notification style and change it to sound
Step 5 - a new sound option will pop up and allow you to pick your sound (built in or downloaded and put into notification folder)
That's pretty much it.
Wish I could tell yous how to do this without the phone being at 100% but I don't change my sound ever so I had to wait lmao
