    I don't want to overcharge the phone when I go to bed, so a notification would help me.
    10-05-2019 10:19 PM
  2. mustang7757's Avatar
    Hi, welcome to Android Forums
    I'd like to recommend creating a account so me or other members can assist you, as guest have limitations in replying here and if we need further Information to communicate with you.
    I'll provide a link to register, please come back to your post so we can further assist you . Thank you
    https://forums.androidcentral.com/sh...d.php?t=409154
    10-05-2019 10:22 PM
  3. fuzzylumpkin's Avatar
    You can use an app like GSam. But you're not going to overcharge the battery anyway, there's far too much overcharge protection in place.
    Charge it when you go to sleep, unplug it when you wake up.
    10-06-2019 08:44 AM
  4. BaritoneGuy's Avatar
    Both my S10 and Tab S6 provide a notification when fully charged. I am not sure what setting this is as I did not explicitly set it up to do so.
    As stated by fuzzy Lumpkin I wouldn't worry about it as the phone stops charging at 100%.
    One thing I would like is the ability to tell it to stop charging when the battery reaches a specified percentage.
    Morty2264 likes this.
    10-07-2019 07:04 PM
  5. lucianus_luciferus's Avatar
    10-09-2019 04:59 PM
  6. Morty2264's Avatar
    What a wonderful saying. It never gets old.
    10-09-2019 05:05 PM
  7. BaritoneGuy's Avatar
    That would assume I am near the phone to pull it off the charger. Wish I could set it to just stop charging at a predefined level.
    10-09-2019 06:11 PM
  8. rolexreviews's Avatar
    You do NOT need an app.
    Wait till your phone reaches 100% and you'll get a notification that your phone has been fully charged.
    long press the notification and you'll see in there it says Popup notifications (should say silent) click that and pick a sound and you're done.
    I used the Pokemon Center Healing sound whenever my phone charged to 100%
    (I don't have the exact instructions on how to do it because my phone isn't at 100%, soon as i get the phone to 100% I will make the instructions more accurate)
    10-09-2019 08:23 PM
  9. fuzzylumpkin's Avatar
    Hahaha, I have the same sound!
    10-10-2019 04:28 AM
  10. Morty2264's Avatar
    OMGOSH I need to set the Pokémon Centre healing sound as my notification!!!! Thank you so much, that's genius!
    10-10-2019 09:30 AM
  11. rolexreviews's Avatar
    ok so I now have full instructions because my phone is fully charged.
    Step 1 - when the full charged notification shows up press and hold it
    Step 2 - press "details"
    Step 3 - Touch where it says Battery Full Silent
    Step 4 - Touch where it says notification style and change it to sound
    Step 5 - a new sound option will pop up and allow you to pick your sound (built in or downloaded and put into notification folder)
    That's pretty much it.
    Wish I could tell yous how to do this without the phone being at 100% but I don't change my sound ever so I had to wait lmao
    10-10-2019 09:58 AM
  12. fuzzylumpkin's Avatar
    Wish I could tell yous how to do this without the phone being at 100% but I don't change my sound ever so I had to wait lmao[IMG=485x1024]https://uploads.tapatalk-cdn.com/20191010/703be5b280e1a480c6b8120f8756b42e.jpg[/url][IMG=485x1024]https://uploads.tapatalk-cdn.com/20191010/e26ba9b152a73c337a3a6e2968bc7e45.jpg[/url][IMG=485x1024]https://uploads.tapatalk-cdn.com/20191010/09b964829dc8715c9130a489b248e32f.jpg[/url][IMG=485x1024]https://uploads.tapatalk-cdn.com/20191010/342fd060146a63408569024391996d00.jpg[/url][IMG=485x1024]https://uploads.tapatalk-cdn.com/20191010/dc2b2aba728778b1bfbf66e5ae06727d.jpg[/url]
    When you have the phone on charge, you can slide the charging notification to the side and get to the settings from there.
    It's worth noting that the reason i advised GSam is because this doesn't work for me. For whatever reason the fully charged notification doesn't trigger.
    10-10-2019 10:26 AM
  1. Only one wireless earbud will connect on new s10 phone
    By Jeremiahts in forum Samsung Galaxy S10 & S10+
    Last Post: 10-09-2019, 06:01 PM
  2. Any idea why SideSync is Not available for Note 10?
    By Lepa79 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 10-08-2019, 11:33 AM
  3. Who or what is zwieback?
    By A2Steve in forum General Help and How To
    Last Post: 10-06-2019, 07:18 PM
  4. How i back the device that i deleted in blutooth
    Last Post: 10-06-2019, 01:02 PM
  5. Destroy All Humans: Everything you need to know about the remake
    By Android Central Question in forum Android Games
    Last Post: 10-05-2019, 09:32 PM
