    I've managed to thoroughly confuse myself. I need a rapid-charge wall charger for my Samsung S10+. I'm confused as to which part (cable or adapter or both) are necessary for the fast charging to work. I've been searching around Amazon and Best Buy and I'm getting nowhere.
    What, exactly, should I be looking for?
    10-08-2019 07:16 PM
  2. mustang7757's Avatar
    Hi, welcome to AC Forums, if you use the Note 10+ stock wire and brick should be ok , it's a fast charger. If you have more questions please register here.https://forums.androidcentral.com/sh...d.php?t=409154
    10-08-2019 08:13 PM
  3. andrea java's Avatar
    I don't have the Note...this is the S10+. I have the stock charger...I need an additional one for work. Thanks.
    10-08-2019 08:35 PM
  4. Javier P's Avatar
    I moved your thread to the S10+ forum where it'll be easier getting help from other owners.
    10-08-2019 08:37 PM
  5. mustang7757's Avatar
    Hi, welcome!
    What I mean is if you get the stock Note 10+ charger it's a fast charger and a Samsung one
    10-08-2019 08:51 PM
  6. andrea java's Avatar
    Hi, welcome!
    Ohhhh, I see now. Thank you. But I'm still curious about how it works... Can anybody shed light on that? Is the speed due to the cable or the adapter? Or both?
    10-08-2019 10:45 PM
  7. mustang7757's Avatar
    No problem, the stock Samsung s10+ adapter is 15w and Note 10+ adapter is 25w so I would get both adapter and Cable
    10-08-2019 10:49 PM
  8. fuzzylumpkin's Avatar
    Well, sorry to confuse the issue, but if i were you I'd get a USB-PD charger and a C to C cable from someone like anker. No point paying a premium for a Note charger.
    10-09-2019 05:00 AM
  9. Gayle Lynn's Avatar
    Things to consider. I use the 30W Apple adapter also you may want a wireless stand or pad ,- no cables and very convenient when at s desk.
    Finding things on Amazon is s nightmare, why I don't know but we know Google made searches A+.
    Anker 30W PIQ 3.0 & GaN Tech Power Delivery USB C Charger, PowerPort Atom III Slim Compact Type-C Charger for iPhone 11/11 Pro / 11 Pro Max/XR/XS/Max, Galaxy, Pixel, MacBook and More
    www.amazon.com/dp/B07PT7XMP9/
    Does AC really need to add refer to URLs ?
    10-09-2019 05:11 AM
  1. Replies: 10
    Last Post: 10-09-2019, 07:06 PM
  2. Selfie Camera Problem S10 plus
    Last Post: 10-09-2019, 01:44 PM
  3. Google lens keeps crashing on my LG K10. how do I fix it?
    Last Post: 10-09-2019, 12:59 AM
  4. What does it mean when the little green robot man pops up during a phone call.
    Last Post: 10-09-2019, 12:52 AM
  5. Mr Samsung S9 will not allow me to pick up an incoming call
    Last Post: 10-08-2019, 07:04 PM
