1. Celtic96's Avatar
    Edge Lighting is turned on, notifications set to sound and pop up, contacted Samsung, was told to reset settings which I did. Still nothing. Also, I can't get my screen to wake up when a text comes in. So maddening with all the settings on here.
    11-09-2019 07:36 PM
  2. mustang7757's Avatar
    Hi, welcome to Android Forums
    I'd like to recommend creating a account so me or other members can assist you, as guest have limitations in replying here and if we need further Information to communicate with you.
    I'll provide a link to register, please come back to your post so we can further assist
    https://forums.androidcentral.com/sh...d.php?t=409154
    11-09-2019 07:37 PM
  3. Celtic96's Avatar
    Thank you--created an account and reposted
    mustang7757 likes this.
    11-09-2019 08:12 PM
  4. mustang7757's Avatar
    Hi , welcome!
    Can you show me a screenshot of the settings in edge panel ? Just block any personal information
    11-09-2019 08:16 PM
  5. Celtic96's Avatar
    11-09-2019 08:38 PM
  6. mustang7757's Avatar
Name:	Screenshot_20191109-203350_Edge   screen.jpg
    I have for all apps notifications , I see you have 2 only Edge Lighting Not work even though turned on with S10-screenshot_20191109-204033_edge-20screen.jpeg
    11-09-2019 08:41 PM
  7. Celtic96's Avatar
    Yes, because I only want it for Texts and voice mail. I thought you could select which apps? Too many settings on this S10! I have those apps selected, which are not 3rd party apps.
    11-09-2019 08:44 PM
  8. mustang7757's Avatar
    Your right lol there is lot of settings
    Yeah that's fine just those 2 .
    You use DND ?
    11-09-2019 08:50 PM
  9. Celtic96's Avatar
    No, I don't use the Do not Disturb feature
    11-09-2019 08:52 PM
  10. mustang7757's Avatar
    Ok...then I'm going ask you reset app preference in settings >apps tap it >3 dots upper right corner tap > scroll to reset app preference see if this helps
    11-09-2019 08:54 PM
  11. BaritoneGuy's Avatar
    Do you have a 3rd party launcher installed? They can sometimes get in the way of this.
    11-11-2019 07:12 PM
  1. My phone is not ringing?
    By randyjaco in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 11-20-2019, 08:25 AM
  2. no names on incoming calls
    Last Post: 11-10-2019, 01:22 PM
  3. Gmail error on s10
    By Rutger11 in forum Samsung Galaxy S10 & S10+
    Last Post: 11-10-2019, 11:59 AM
  4. videos on samsung galaxy note 3 phone
    By Android Central Question in forum Samsung Galaxy Note 3
    Last Post: 11-09-2019, 10:25 PM
  5. videos on samsung galaxy note 3 phone
    Last Post: 11-09-2019, 05:11 PM
