    Downloaded A10 yesterday now missing at least 6 hours on battery life. We need this sorting out now
    12-10-2019 03:50 PM
  2. belodion's Avatar
    Have you sent feedback tó Samsung őr Google?
    12-10-2019 04:52 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Are you saying that the battery is draining faster? Keep in mind that for the first day or so after doing a major upgrade, the battery might drain a little faster due to the update activity itself, and possibly also a number of apps updating.
    Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which may show Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html. Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    12-10-2019 05:27 PM
  4. belodion's Avatar
    We obviously can't help if you don't respond.
    Gayle Lynn likes this.
    12-15-2019 11:53 AM
  1. Replies: 5
    Last Post: 12-18-2019, 09:14 PM
  2. S9+ slightly used or S10 new?
    By jlrenew in forum Samsung Galaxy S10 & S10+
    Last Post: 12-13-2019, 07:47 AM
  3. Transfer to new microsd produced files with leading "._" on them.
    By migs_inc in forum Samsung Galaxy S10 & S10+
    Last Post: 12-10-2019, 06:45 PM
  4. Can someone else with your goole account and password turn on your location
    Last Post: 12-10-2019, 03:04 PM
  5. Download icon missing from status bar in Samsung Galaxy S8
    Last Post: 12-10-2019, 02:26 PM
