1. Saintor's Avatar
    I bought a wireless charger and it works ok.... until I have my case & steel plate then I get an overheat messages.
    The rectangular steel plate (about 2 3/8 x 1 3/4( was installed north-south (long side) at the bottom.
    I moved it west-east just below the lenses. I still get the message.
    Somebody (with an Iphone) suggested that this plate is too large. There are smaller round plates (1 1/4 or so) and if installed at the bottom, it won't trigger this message. He told me that in his phone, the "receiving" component was in the middle of the frame
    Any experience with this?
    02-13-2020 07:16 PM
  2. B. Diddy's Avatar
    What's the steel plate for? My guess is that the plate as well as the case are interfering with the phone's ability to dissipate the heat generated by the wireless charging.
    02-13-2020 07:19 PM
  3. Saintor's Avatar
    This is to put on a magnet mount in my car.
    https://cdn.shopify.com/s/files/1/09...g?v=1576525426
    02-13-2020 07:24 PM
  4. methodman89's Avatar
    Any metal placed between the coil and inductor shall produce heat, enough to melt your equipment. I've posted pics previously of this noncompatibility showing my melted charger.
    Be cautious, as most wireless chargers have multiple coils to react with.
    Good luck
    02-14-2020 05:07 AM
  5. Saintor's Avatar
    Correct, I checked and mine has two coils, so trying to move the plate's position won't help.
    02-14-2020 09:56 AM
  1. Ads on my phone even when not in an app
    Last Post: 02-14-2020, 07:43 AM
  2. Replies: 6
    Last Post: 02-14-2020, 07:24 AM
  3. LGG7 Poor battery life and charging problems
    Last Post: 02-14-2020, 02:21 AM
  4. Slow charging after 90% happening sometimes?
    By milleniumdroid in forum General Help and How To
    Last Post: 02-13-2020, 04:34 PM
  5. Replies: 0
    Last Post: 02-13-2020, 12:25 PM
