02-21-2020 07:05 AM
31 12
tools
  1. methodman89's Avatar
    I don't really understand what you mean. I only have one Wi-Fi network I can access...the one assigned to my apartment. I feel I'm missing something here. I have checked all the settings you suggested, and you can see that from the screenshots. So I not sure how I can access other networks? I tried at work and at a friend's place on different Wi-Fi networks but the vpn will not connect on any Wi-Fi.
    If you change your mind, reread my posts regarding VPN settings on the device, and checking the network settings through the Connections in the phones Settings. Good luck.
    02-18-2020 02:17 PM
  2. Weatherbain's Avatar
    I have looked through your posts and for whatever reason, I cannot find the settings you are suggesting. They simply don't exist in my phone. I took screenshots showing the Wi-Fi connection settings from my Samsung phone and also from my Huawei phone, as follows:
    Attached Thumbnails VPN connects fine on 4G but will not connect on Wifi on my Galaxy S10+ phone-screenshot_20200221-153800_settings.jpg   VPN connects fine on 4G but will not connect on Wifi on my Galaxy S10+ phone-img-20200221-wa0028.jpg
    02-21-2020 06:42 AM
  3. Weatherbain's Avatar
    I just tried something random now...I turned off the "use data lge for calls wherever possible"setting. And now it's connecting on Wi-Fi! It doesn't stay connected for long, but at least it responded. Could that have been the issue all along?
    02-21-2020 06:52 AM
  4. Kirstein Gourlay's Avatar
    Sounds like it could be
    02-21-2020 06:58 AM
  5. Weatherbain's Avatar
    Well just when I thought that might be the solution, it no longer connects again. I'm completely stumped.
    02-21-2020 07:00 AM
  6. methodman89's Avatar
    Somewhere, under More Connection Settings is the VPN Setting for the phone itself.
    Try typing VPN in the Settings searchbar.
    02-21-2020 07:05 AM
31 12
  1. Replies: 1
    Last Post: 02-18-2020, 02:33 AM
  2. Replies: 4
    Last Post: 02-15-2020, 08:02 PM
  3. Why is my network not working
    Last Post: 02-15-2020, 06:42 PM
  4. Google Play Services not supported and many apps uninstalling?
    Last Post: 02-14-2020, 11:24 PM
  5. How do I get rid of the little man in the right corner of my phone
    Last Post: 02-14-2020, 10:36 PM
