1. technologicguy's Avatar
    Good morning! I've been using my Galaxy S10e and love it for the most part. However, a lot of problems have been coming out of various camera apps. I've paid for multiple apps that have an awful time capturing, file format issues, and allowing any kind of decent video quality. When I discovered the Pro Video option in the default camera app, I've been getting much better results with that except for frame rate. When I want to simply record at a static frame rate of 29.97, I can't. For my latest video project, I exported all four video files over into Premiere Pro, and their displayed frame rate shows them each stacked at:
    30.03 fps,
    30.00 fps,
    29.81 fps,
    29.69 fps,
    So I'm completely at a loss as to how to adjust this in my settings to record at 29.97 fps every time. Paid camera apps have done the same thing, and their quality is garbage so I don't have plans to keep hemorrhaging more money for more crappy apps. I'd really like to just figure this out. Any thoughts? Thank you in advance!
    07-01-2020 11:14 AM
  2. technologicguy's Avatar
    Bumping.
    07-02-2020 09:37 PM
  3. mustang7757's Avatar
    [Moved this from s10 forums to s10e]
    Hopefully get you some traffic
    07-02-2020 09:43 PM
  4. technologicguy's Avatar
    Didn't even see an S10e option, thanks.
    mustang7757 likes this.
    07-02-2020 11:24 PM
  5. mustang7757's Avatar
    No problem, I wish I could offer suggestions for you but all my phones I use stock camera apps, I'm not crazy about 3rd party ones.
    07-02-2020 11:27 PM
  6. technologicguy's Avatar
    Neither am I anymore. I love the built in Pro Video option, I just have to get this frame rate problem dialed down. Thanks again!
    07-02-2020 11:49 PM
  7. mustang7757's Avatar
    Your welcome
    07-02-2020 11:56 PM
  8. technologicguy's Avatar
    Hey I'm reaching out again, it's been nearly 3 days and I haven't actually heard back regarding any responses on this topic. I may just repost the whole topic again if this is not reaching anyone.
    07-03-2020 10:57 PM
  9. mustang7757's Avatar
    No need to repost, you just brought it back up to the top.
    07-03-2020 11:13 PM
  10. mustang7757's Avatar
    Try reseting your camera app?
    07-03-2020 11:16 PM
  11. technologicguy's Avatar
    I wasn't meaning to send you another message, I am trying to just make another general post to alert the main forum, that it has been nearly 3 days with no response on this. I've obviously tried resetting it. So far I'm not having a good experience here, and I just need someone who knows how these phones function. If no one knows, it's better that a large array of them come forward and simply say they don't know, otherwise, I have no way of knowing if this is reaching anyone beyond you. As I said, I'm not trying to send you more messages, I want to speak to people that have used the S10e.
    07-03-2020 11:41 PM
  12. mustang7757's Avatar
    Understand, I put you in correct forum, as you had 345 views so far, if no one will come through I will try help you figure it out, I'm experienced Samsung member here, so I have the s10+ and Note + phones. The s10e stock camera app have both 30fsp and 60?
    Reset, did you do this in camera app settings or long press tap info and scroll to storage clear data, cache and force stop?
    07-04-2020 12:07 AM
  13. Mike Dee's Avatar
    30.03 fps,
    30.00 fps,
    29.81 fps,
    29.69 fps,
    Are you saying you see glitching between the different frame rates?
    07-04-2020 09:07 AM
  14. technologicguy's Avatar
    Mustang,
    Whatever is causing this, that's not it. You can know that I've made extensive attempts at things like that and it hasn't resolved the issue.
    07-05-2020 08:14 AM
  15. technologicguy's Avatar
    Mike,
    I suppose glitching could be one word for it, but yes. Because the frame rate is not exact for all clips, there is skipping in the footage of my projects.
    07-05-2020 08:16 AM
  16. Mike Dee's Avatar
    Mike,
    Does this happen at higher resolutions with 60FPS?
    07-05-2020 08:40 AM
  17. technologicguy's Avatar
    Yes, I have old files that ended up recording at 60.10, and 58.89. I have no idea why it does this, but purchased app or not, I cannot get it to record at 29.97. The phone chooses a frame rate close to that, and randomly records what it wants every time.
    07-05-2020 09:39 AM
  18. mustang7757's Avatar
    Mustang,
    That's why I'm asking questions, see what exactly you have done.
    07-05-2020 10:55 AM
  19. Fred98TJ's Avatar
    Since video is so important to you (obviously) I would suggest getting a real camera that has a emphasis on video
    I realize this doesn’t solve your immediate problem, nor answer your question directly, however it seems quite obvious that you’re getting no where fast and really getting bent.
    Cheers
    07-13-2020 06:02 PM
  1. An app that is just a live rear camera feed?
    By Zarquan314 in forum Android Apps
    Last Post: 09-08-2020, 03:46 PM
  2. Default Contacts issue.
    By missionsparta in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 07-13-2020, 11:32 AM
  3. S10e Default Camera erratic frame rate?
    By technologicguy in forum Samsung Galaxy S10 & S10+
    Last Post: 07-02-2020, 09:37 PM
  4. Migrating from Xperia to Galaxy, could use some help with camera/album apps.
    By Old_Skewler in forum Samsung Galaxy S10 & S10+
    Last Post: 07-02-2020, 07:39 PM
  5. Replies: 1
    Last Post: 06-30-2020, 04:07 PM
