1. Eran123m's Avatar
    I have Samsung s10e, i i am using "double tap to wake", but i can't see anywhere "double tap to lock", how can i lock the phone using double tap?
    06-18-2021 12:59 AM
  2. B. Diddy's Avatar
    Go to Settings>Advanced Features>Motions and Gestures and look for the option there. http://www.samsung.com/au/support/mo...p-to-turn-off/
    wilsodw likes this.
    06-18-2021 01:40 AM
  3. gomezz's Avatar
    To Double Tap to Lock then double tap on any blank part of the Home Screen.
    06-18-2021 04:22 AM
  4. Morty2264's Avatar
    I miss having that "double tap to lock" feature!
    06-18-2021 07:09 AM
  5. B. Diddy's Avatar
    Right, but you have to have that option turned on first for it to work.
    mustang7757 likes this.
    06-18-2021 10:03 AM
  6. mustang7757's Avatar
    Yes need that on first
    06-18-2021 11:15 AM
  7. evanborkow's Avatar
    According to my phone, double tap turns off the screen not lock the phone.
    06-18-2021 04:36 PM
  8. B. Diddy's Avatar
    Which phone do you have? It'll depend on the phone manufacturer (and also the launcher).
    06-18-2021 04:44 PM
  9. evanborkow's Avatar
    S10e stock on Verizon.
    06-18-2021 04:49 PM
  10. gomezz's Avatar
    Do you have Smart Lock rules in play?
    I use an app called Lockdown Mode from Android P went I want to override my Smart Lock rules. Put the widget from that on the Home Screen to give you a single tap to lock
    https://play.google.com/store/apps/d...hl=en_GB&gl=US
    06-18-2021 05:27 PM
  11. B. Diddy's Avatar
    Under Secure Lock Settings, change the "Auto lock when screen turns off" interval to Immediately if you want the double tap to lock the phone as well.
    06-18-2021 05:31 PM
  12. wilsodw's Avatar
    Yep, Verizon S10e its right where you said it was.
    06-18-2021 09:23 PM
  13. evanborkow's Avatar
    Yes, it's the Smart Lock rules.
    06-19-2021 08:47 AM
  1. widget on lock screen
    By ScttLee184 in forum Android Apps
    Last Post: 07-22-2021, 11:18 AM
  2. What happens to my text when l click on the envelope on the top right hand side
    Last Post: 06-17-2021, 08:43 PM
  3. 3XL Developer options - which do you toggle on to improve performance?
    By mrpackerguy in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 06-17-2021, 04:04 PM
  4. Google Assistant from locked device
    By Kurosaki_kun in forum Ask a Question
    Last Post: 06-17-2021, 03:04 PM
  5. Access to Forums
    By Android Central Question in forum Site Feedback & Help
    Last Post: 06-17-2021, 09:44 AM
