You mean Chrome, or do you mean you use the Google app to do a search, and then open the result directly in the Google search app's browser?
Does it occur in safe mode?
FYI, the OP addressed the unfeasibility of using Safe Mode in post no. 5 above.
How do you access the forums?How do I unsubscribe from this forum? I upgraded to an S22+
Did you ever get it fixed?
My wife's dies the same thing
New phone and it happened again
She is on Verizon
Not. NFC
We haven't found the Chime sound in her library.
Any input desired. I will repost the question later this week.
TY
Try some of the things mentioned hereDid you ever get it fixed?
She is on Verizon
Not. NFC
TY
She is on Verizon
Not. NFC
TY
Seriously, how can there not be a found solution to this? I have looked everywhere I can think. For that last 3 weeks I had not heard it but the last 24 hours it has gone off 3 times. It make me want to throw my phone across the room. Of course that mean they win. So I won't. Other than all the suggestions before, rendering your phone uesless by turning off all your apps for extended periods, and using notification logging apps that don't do anything, is there anything anyone has found? It must be external, as the 3 chime notification sound is not saved into the phone, best I can tell.
