1. anon(10766205)'s Avatar
    It starts out charging at a rate of about 2400mah, then immediately drops to about 1200mah. I tried several things...blowing out the USB port, trying different chargers and cables, restarting the phone, etc. I even did a factory reset. Still the same. And yes, fast charging is switched ON in settings. It will charge, but quite slowly.
    09-26-2021 07:40 AM
  2. B. Diddy's Avatar
    What's the battery level at when this happens?
    Have you already tried cleaning out the phone's USB port?
    09-26-2021 11:28 AM
  3. anon(10766205)'s Avatar
    The battery was at about 40% when I plugged it in. Yes I cleaned the port. It will charge, but only at normal speed.
    09-26-2021 02:31 PM
  4. mustang7757's Avatar
    Try going settings>apps>toggle on system apps then hit ok >search usb settings on the list and clear its data and force stop see if it helps
    Laura Knotek likes this.
    09-26-2021 07:05 PM
  5. anon(10766205)'s Avatar
    Try going settings>apps>toggle on system apps then hit ok >search usb settings on the list and clear its data and force stop see if it helps [IMG=1080x2249]https://uploads.tapatalk-cdn.com/20210927/8d5d01ffc2fd06da896852e02d25357f.jpg[/url]
    I just tried your suggestion. I then plugged charger into phone. Same thing happened. Very frustrating.
    09-26-2021 08:02 PM
  6. mustang7757's Avatar
    Get a flash light and look at the charger port anything looks damaged the pins? Or worn out
    09-26-2021 08:05 PM
  7. anon(10766205)'s Avatar
    It looks amazingly good for a 2 year old phone. I blew it out with compressed air... the port and the cable connector.
    09-26-2021 09:51 PM
  8. mustang7757's Avatar
    Thats good, have you tried clear cache in recovery?
    09-26-2021 09:54 PM
  9. anon(10766205)'s Avatar
    No, where is recovery located?
    09-26-2021 09:56 PM
  10. mustang7757's Avatar
    You have to turn the device off , as u power on hold the volume up/power button same time to enter recovery then select with volume buttons and and highlight wipe cache then power button to clear
    09-26-2021 09:58 PM
  11. isabel95's Avatar
    It has been my experience with my former Note 4 that the charger can go back and that its replacement will restore proper charging. As a matter of fact, I don't use fast charging because it makes the battery get hotter, so I turn it off. I also remove the case and charge only to 80% with the help of the app, AccuBattery, which alerts me to when 80% is reach. I also try to get it to go no lower than 20%. Last test I did on the two year old battery showed it has 96% of its capacity left. Even with fast charging turned off it recharges very quickly.
    09-27-2021 09:20 AM
  1. Replies: 5
    Last Post: 09-26-2021, 09:04 PM
  2. Remember my choice
    Last Post: 09-26-2021, 08:01 PM
  3. Wireless charging mouse pad and "ghost touches?"
    By Youchan3070 in forum General Help and How To
    Last Post: 09-26-2021, 11:45 AM
  4. Pixel 4a: Notifications bar suddenly stopped working
    Last Post: 09-25-2021, 06:20 PM
  5. My infinix hot 8 lite
    Last Post: 09-25-2021, 11:31 AM
