1. blazers88's Avatar
    On the apps section of the edge panel, the empty slots you don’t use still show up with “+” inside them. Anyway to hide them? Looks pointless and ugly
    05-30-2019 10:08 PM
  2. mustang7757's Avatar
    I dont think you can , just fill them up lol
    tube517 likes this.
    05-30-2019 11:05 PM
  3. tube517's Avatar
    Exactly what I do. I dont even use the edge panel that much
    mustang7757 likes this.
    05-30-2019 11:17 PM
  4. mustang7757's Avatar
    I dont either
    tube517 likes this.
    05-30-2019 11:20 PM
  5. frifred's Avatar
    I like the Edge panel, but wish that you could widen the "handle" to make it easier to open (since many glass screen protectors don't cover the entire screen, they interfere with being able to easily open the Edge panel). I have one unused slot on my apps panel and I just ignore it. I figure that sometime down the road I might find something to put in that spot. I also use the contact panel, handy in quickly opening oft used contacts.
    Dooki likes this.
    06-01-2019 07:03 AM
  1. Remove "goodluckday" browser hijacker
    Last Post: 05-30-2019, 08:50 AM
  2. How do I remove this annoying second screen in my LG V20? [Solved]
    Last Post: 05-29-2019, 12:21 AM
  3. Replies: 3
    Last Post: 05-28-2019, 05:51 AM
  4. Replies: 1
    Last Post: 05-27-2019, 10:51 PM
