Originally Posted by
Android Central Question Brand new s10e - no issues other than when connecting to a wireless charger after a second a battery temp too low charging error comes up and never clears.
I've tried a few different qi chargers up to 10w and get the same issue. Sometimes it will cause the battery percentage to drop 10/20% (although I suspect this is purely on the software as it then takes far longer to discharge the remaining)
Been through the cache partition clearing, resetting preferences etc.
No issues at all re wired charging so don't this this is a thermistor issue.
Any ideas to fix?
First find a known working qi charger, maybe a friend, coworker, or the store you got it from.
