    I use ethernet adapter to connect my Galaxy S10e to the LAN cable and turn on Wi-Fi hotspot to get a decent Wi-Fi signal in my room, while charging the phone simultaneously on a Qi charger. But when the phone gets to 100% and stops charging for a bit, ethernet connection drops and so does my internet now. I tried to keep the display on using Tasker, but even that requires the phone to be charging in some way to keep the display on. How do I fix the issue?
    08-04-2019 01:07 AM
  2. mustang7757's Avatar
    Hi , if you can register a account here , me or other members be happy to assist.
    I'll provide a link to register so you can communicate here.https://forums.androidcentral.com/as...community.html
    08-04-2019 09:08 AM
  3. Rukbat's Avatar
    Look in the Ethernet adapter's app (there should be one) for a setting that allows it to go to sleep under certain conditions (fully charged, screen off, sleeping, whatever). Turn that off.
    08-04-2019 02:02 PM
  4. fuzzylumpkin's Avatar
    Buy a decent WiFi router.
    Or a WiFi switch to plug your Lan cable into.
    You're causing yourself problems by overcomplicating a problem with a simple solution. You'll also wreck your phone doing this long term.
    08-04-2019 04:02 PM
  1. Any way to modify what Smart manager deletes on my s5?
    By Dook42 in forum Android 6.0 Marshmallow
    Last Post: 08-04-2019, 04:20 PM
  2. Replies: 4
    Last Post: 08-04-2019, 02:30 PM
  3. Managing notifications from the notifications banner?
    By android_freak1 in forum Samsung Galaxy S10e
    Last Post: 08-04-2019, 12:51 PM
  4. Replies: 7
    Last Post: 08-04-2019, 05:08 AM
  5. how do i get rid of this app.
    Last Post: 08-04-2019, 12:40 AM
