Hey I currently have the Pixel 4XL and I'm thinking about jumping back on the Samsung train but I'm concerned about the 120hz not being in QHD. Do we know for sure if the S20+ or Ultra will be getting the update or not?
I believe there's a hardware limitationHey I currently have the Pixel 4XL and I'm thinking about jumping back on the Samsung train but I'm concerned about the 120hz not being in QHD. Do we know for sure if the S20+ or Ultra will be getting the update or not?
Yes if sim unlocked, works on all 4 carriersWould you know if an AT&T S20 Ultra will work on the T-Mobile network?
It was reported that it's a hardware limitation on the S20.
Note 20 Plus should have it.
https://www-sammobile-com.cdn.amppr...will-probably-never-get-120hz-qhd-resolution/
Well I'm going to hold off then and not get the S20 Ultra. I have the Pixel 4XL but miss that beautiful Samsung screen so I'm going back to the Note10+.
