1. Nodnerb's Avatar
    I got this on my note 10+. Haven't been able to charge it since and googling shows it has been an issue for some samsung phones for several versions back. Warning says "temp too low, charging will resume when temperature increases". Others who have had the issue have sent their phone in for warranty only to get it back with the same problem. Only real fix is a new phone which obviously samsung fights to the death to avoid.
    I will send it in to see what happens but since am off contract I am looking at switching carriers and getting an s20 plus, but may think twice if these phones are having the same issue.
    Has this happened to anyone with any version of the s20? Unfortunately there is nothing by any other brand that is enticing right now. Not an apple fan at all, Huawei are nice hardware but without google a big NOPE, LG are just stagnant etc. etc. There's just nothing out there.
    Thanks for any input.
    06-05-2020 08:20 AM
  2. msm0511's Avatar
    Here's a recent thread about some Note 10 users with the same issue.
    https://forums.androidcentral.com/sa...e-too-low.html
    06-05-2020 08:27 AM
  3. Nodnerb's Avatar
    Thanks, I did a search first and did go through that thread. Also found others on other forums. I've already factory reset and nothing has changed. I get the warning and a strange alarm sound any time I try charge it. And sounds like it'll be a nightmare to try get it fixed under warranty but will try anyway. I wish there was something out there that interested me other than samsung. Doesn't help that I also have a galaxy watch I'm addicted to and a tab s6. Right now using my wife's old s7 just for texts and calls in the mean time.
    06-05-2020 08:35 AM
  4. methodman89's Avatar
    Try Disable Sensors in developer option, then highlight the Sensor icon from the pull down.
    Good luck
    06-05-2020 10:00 AM
  5. Lobwedgephil's Avatar
    I haven't seen this on my Ultra, but I also haven't ever seen this on any previous phone either.
    06-05-2020 12:00 PM
  6. B. Diddy's Avatar
    I think sometimes it's due to debris in the charge port -- make sure it's clean by using a can of compressed air to blow it out, or a computer vacuum.
    06-05-2020 12:28 PM
  7. methodman89's Avatar
    If you enable developer options, you should find the icon circled.
    06-05-2020 12:38 PM
  8. B. Diddy's Avatar
    As @methodman89 also noted in his other thread, be aware that turning the sensors off can interfere with proper function of the Camera app: https://forums.androidcentral.com/as...ml#post6799068
    06-05-2020 12:53 PM
  9. methodman89's Avatar
    I'm not even sure if it will disable that temperature sensor.
    06-05-2020 04:03 PM
  1. Do the permissions for GBoard keyboard scare anyone?
    By java518 in forum General Help and How To
    Last Post: 06-04-2020, 01:51 PM
  2. Do the permissions for GBoard keyboard scare anyone?
    By java518 in forum Android Apps
    Last Post: 06-04-2020, 01:43 PM
  3. Replies: 1
    Last Post: 06-04-2020, 02:55 AM
  4. Replies: 7
    Last Post: 06-04-2020, 01:15 AM
