1. jtcannonball's Avatar
    So I am pumped because today is the day my new s20 Ultra arrives. Update it and take it to the lake. Take photos at max res to get that killer detail. So much lag between pushing the button and the camera taking the image. That's understandable because it's evening and the sun is shining right at us and it's a large file. But the kicker is 80% of my photos don't even save. Just snap and nothing. Tried standard 12mp and then the HDR was bonkers and no solid results from that either. The last thing I've noticed is it seems like a lot of play with my charging port. Not sure how much play they normally have but it's not giving me the most confidence. And the last last thing is complete lag and frozen screens while typing. Happens with stock and swift. So I'm going to hopefully see if there is any work around for some of these things but I might be doing a return. Not sure how Samsung does exchanges if I went that route.
    07-03-2020 10:15 PM
  2. Kizzy Catwoman's Avatar
    I am sorry your new phone has not performed the way you hoped it would. People have said the updates to the camera have helped, although I don't have personal knowledge.
    There shouldn't be a lot of play with the charging port. My S10+ is pretty tight.
    I do have a little lag on my S10+. I factory reset it and I am still getting some lag at times. Especially the messages app. But if it isn't performing as expected maybe a return isn't a bad option.
    Hoping people with the phone will chime in with their points of view.
    07-03-2020 10:49 PM
  3. V J's Avatar
    You have a failing micro SD card.
    07-04-2020 06:01 AM
  4. jtcannonball's Avatar
    Thanks for the attempt to help, I’m glad for any help but I’ve no Micro SD in it. Just the stock memory.
    07-04-2020 06:52 AM
  5. Morty2264's Avatar
    I'm so sorry you are having issues with your new phone! With regards to your camera, I would recommend trying to boot your phone into Safe Mode to see if that makes any difference. Are you using any third-party photo editing apps, or anything like that?
    As Kizzy said above, your port should be snug and tight. Perhaps returning the phone is the safest option. Please keep us updated!
    kct1975 likes this.
    07-04-2020 08:54 AM
  6. jtcannonball's Avatar
    I had just updated it with no apps downloaded as I didn’t have time. It seems to be faster today but the port is worrisome. The camera seems much faster today once it’s been fully charged.
    Morty2264 likes this.
    07-04-2020 09:08 AM
  7. Morty2264's Avatar
    That is good that the camera seems snappier! But I am worried ahout the port being loose like you've mentioned. Do you charge your phone in another room? If you do, I'd recommend charging it in a place where you can keep an eye on it.
    07-04-2020 01:20 PM
  8. jtcannonball's Avatar
    It’s got play up and down. It feels like it snaps in but then the cable moves a bit at the base.
    07-04-2020 01:39 PM
  9. Kizzy Catwoman's Avatar
    Just keep an eye on it please
    07-04-2020 03:41 PM
  10. regor60's Avatar
    The "port" seems loose... really ?
    Perhaps the charging cord is under-dimensioned due to poor design or wear ?
    buzzy3970 likes this.
    07-05-2020 07:22 AM
  11. jtcannonball's Avatar
    Brand new so not a wear issue. Just looks like it wiggles up and down
    07-05-2020 08:58 AM
  12. Morty2264's Avatar
    I would definitely keep an eye on it. This is still a new device and the chargers and cables are new, as well, correct? They shouldn't have defects due to age or use if they just came out of the box.
    We are concerned for your safety - please keep an eye out when you are charging your device. Perhaps do not leave it on the charger overnight.
    07-05-2020 09:31 AM
  13. felloffthetruck's Avatar
    Welcome to the world of Andriod.
    07-05-2020 01:19 PM
  14. jtcannonball's Avatar
    Longtime user, must like to torture myself. Lol
    felloffthetruck likes this.
    07-06-2020 09:33 PM
  15. mustang7757's Avatar
    I like you gave it another shot, it still didn't fit the bill, I respect that.. Hopefully Note 20 or another phone will.
    07-06-2020 10:22 PM
  16. jtcannonball's Avatar
    I’ll put up with a lot for any shortcomings on a Note. I feel the extras and usability for me make up for the deficits. Add gcam and I’ll be set. But the cost of the Ultra being wrapped around the camera and the results are not any better than my old Note for that price isn’t something I’m willing to live with. I love innovation so I’m hoping the next iteration will be bonkers.
    mustang7757 likes this.
    07-07-2020 01:32 PM
  17. mustang7757's Avatar
    Understand
    07-07-2020 02:33 PM
  1. Where can I buy an S20 with Snapdragon in Europe?
    By Liorid in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 07-06-2020, 02:39 PM
  2. my OppO R9skt has internal of 64GB, but I cant access it?
    Last Post: 07-05-2020, 04:41 PM
  3. Replies: 2
    Last Post: 07-05-2020, 04:37 PM
  4. why is my app store not working
    Last Post: 07-05-2020, 12:13 AM
