Verizon Galaxy S20 Ultra software help needed.
Horr1bleK1tten
359
13
I have the galaxy s20 ultra verizon variant, and I am on t-mobile. Is there any way to flash the firmware to the t-mobile variant and also get t-mobile 5g?
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,533
6,108
113
This is the steps :
Windows computer needed
Latest Odin can Google it and download should be 3.14. 1
Download samfirm v0.4.1 tool or frija , extract it with 7zip.
You will extract files for Odin once download with 7zip and will do same for firmware with 7zip .
There will be 4 files after you extract the firmware
BL
AP
CP
CSC
Each of those files will go in Odin when you open to the corresponding slots
BL
AP
CP
CSC USE HOME CSC FIILE TO SAVE DATA
Home data slot dont put nothing
connect your phone with cable to computer , once the files are in its slots hit start, once done you'll see pass in Odin and it will reboot
Put your model number,region Will be TMB select check for updates , then download the Rom , extract the Rom with 7zip.
*Make sure you put phone in download mode
*If dont see your phone connected in Odin change cables or ports in computer .
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,533
6,108
113
I see the steps but I don't see a link or anything where to get the Rom, sorry this is my 1st time doing this.
No problem, in the beginning I mention, you need to Google either samfirm tool or frija and then extract them, after you put your model number and region TMB and select in the tool download.
Horr1bleK1tten
359
13
hey another question. would I be able to flash the unlocked rom instead and still get tmobile 5g? trying to avoid bloatware. thanks in advance!
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,533
6,108
113
Hi, if your on TMobile you choose TMB
Now for unlocked model you'll need to use it's model number then region tmb , also you need to use Odin prince comsey to flash from Carrier to unlocked , it will factory reset so back up everything.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,533
6,108
113
odin prince comsey, also the ultra model number doesn't come out to download firmware
Odin prince comsey latest file you have to Google and download, it's only way you can go from carrier version to unlocked . As for model number on s20 ultra I'll have to look up , you probably didn't put in the correct one
