I have the galaxy s20 ultra verizon variant, and I am on t-mobile. Is there any way to flash the firmware to the t-mobile variant and also get t-mobile 5g?
Yes,. @mustang7757 specializes in that and should be around any minute.I have the galaxy s20 ultra verizon variant, and I am on t-mobile. Is there any way to flash the firmware to the t-mobile variant and also get t-mobile 5g?
You have read my guidelines, I just laid it outWhere do I get the t-mobile firmware? And I will get tmobile 5g?
No problem, in the beginning I mention, you need to Google either samfirm tool or frija and then extract them, after you put your model number and region TMB and select in the tool download.I see the steps but I don't see a link or anything where to get the Rom, sorry this is my 1st time doing this.
Odin prince comsey latest file you have to Google and download, it's only way you can go from carrier version to unlocked . As for model number on s20 ultra I'll have to look up , you probably didn't put in the correct oneodin prince comsey, also the ultra model number doesn't come out to download firmware
