1. MarvBear's Avatar
    Brand new and facebook katana keeps asking me to close it down because it is overloading system resources. I am not going to wipe my phone and start over. Already uninstalled facebook and reinstalled.
    Didnpt help. so it's a goner unless someone else has a solution.
    07-11-2020 08:10 AM
  2. Mike Dee's Avatar
    What is Facebook Katana and what is the exact issue you are facing?
    07-11-2020 08:19 AM
  3. MarvBear's Avatar
    Katana is the folder in which facebook is installed.
    07-11-2020 08:23 AM
  4. Mike Dee's Avatar
    I disable Facebook because it's a resource hog and just use the browser, however I've never had the issue you mention.
    MarvBear likes this.
    07-11-2020 08:32 AM
  5. B. Diddy's Avatar
    "Katana" is the system-level app name for Facebook. I'm willing to bet that Facebook is just being Facebook (i.e., being a resource hog), and your Device Care app/feature (or similar app you might have installed) is being triggered by it. I don't think there's anything you can do about it if you want to keep using the FB app. Consider using the FB website on your phone's browser, which is pretty functional.
    07-11-2020 11:05 AM
  6. mlblack16's Avatar
    No worries, it's just an issue with the latest update to Facebook. I'm getting the same message.
    There's an app called Simple Social, which is a skin for the old mobile website version of Facebook. It uses very little resources and you're still able to send messages without having to install Messenger.
    07-11-2020 03:41 PM
  7. I_didnt_do_it's Avatar
    I've yet to see that on my s20, but it does happen on my s9+ A LOT!!! Its because Facebook is a trash app that is horrible on your phone's resources.
    07-11-2020 11:09 PM
  8. VidJunky's Avatar
    You had me in the first half...
    Back in the day whenever anyone would have trouble with texting, or really any messaging app, or battery drain FB was usually a big contributor to the issue. Never cleared its own cache, hogged a lot of the resources, ruined a lot of lives... Since then the first two have mostly cleared up. I'd say if you're having issues they're probably temporary.
    MarvBear and benjamminh like this.
    07-12-2020 03:45 AM
  9. Anitabanita24's Avatar
    I just recently installed Instagram, and that is when this message started popping up for me. Are we sure it is the Facebook app and not Instagram, or a combination of the two?
    07-13-2020 10:49 AM
  10. B. Diddy's Avatar
    Welcome to Android Central! Instagram is owned by Facebook, so it might be some combination of its components.
    07-13-2020 11:02 AM
  11. MarvBear's Avatar
    Thanks everyone, I am reinstalling FB one more freaking time. I have two Note 4's and a Note 8 in pristine condition and this has never happened, It's a bunch of crap that this happens to an expensive phone like the Verizon s20+ 5G.
    07-13-2020 01:10 PM
  1. Why does my Samsung Galaxy 5 have a circle with a line through it?
    Last Post: 07-13-2020, 06:02 PM
  2. Samsung J1 says "Verizon Wireless not authorized"?
    Last Post: 07-12-2020, 12:13 PM
  3. What's with Android apps updating frequently?
    Last Post: 07-12-2020, 11:16 AM
  4. Can I get Wi-fi Calling on Verizon prepaid with Blu phone?
    By realjet in forum Blu Android Phones
    Last Post: 07-12-2020, 11:09 AM
  5. Replies: 3
    Last Post: 07-12-2020, 12:45 AM
