Re: What am I doing wrong?
Hmm it shouldn't be this way ...do you have touch sensitivity turned on?
Try safe mode to rule out any 3rd party apps
Originally Posted by
bkdodger2 Hmm it shouldn't be this way ...do you have touch sensitivity turned on?
Yep, I've toggled it many times to see if there's a difference. Like I said this is the second device to do this. Originally Posted by
mustang7757 Try safe mode to rule out any 3rd party apps
Ok, but why would the Pixel be fine with the same apps?
Theot Yep, I've toggled it many times to see if there's a difference. Like I said this is the second device to do this. Ok, but why would the Pixel be fine with the same apps?
Different manufacturer , different issues
so I'm in safe mode, seems to work fine but like, I can't really test it with any apps hardly because I don't use most of the stock ones on here.
I'm wondering if its nova? Could it be as simple as the launcher? How do I find out what is causing the issue?
Theot so I'm in safe mode, seems to work fine but like, I can't really test it with any apps hardly because I don't use most of the stock ones on here.
Ok, for Nova just use the stock launcher as default see if still happening, for other apps you will have uninstall one at time until it goes away if it's not the launcher issue.
is anybody else using Nova or another third party launcher with Google's gesture navigation without issue? Because the other issue I have is with recents/multitasking. Its a bit jenky and I can only flip one screen at a time. Sometimes it takes up the whole screen like you are in the app too.
also, this is the slickest screen I've ever used with this factory screen protector. I think part of the problem is my finger or thumb slides past the touch point half the time. Anybody else feel that way? Can I take it off without ruining the screen?
Theot is anybody else using Nova or another third party launcher with Google's gesture navigation without issue? Because the other issue I have is with recents/multitasking. Its a bit jenky and I can only flip one screen at a time. Sometimes it takes up the whole screen like you are in the app too.
Yes recent app with Nova and google gestures is bit wonky, if you use samsung gestures no issue, it google gestures that cause the issue and probably need to be fixed in a update.
mustang7757 Yes recent app with Nova and google gestures is bit wonky, if you use samsung gestures no issue, it google gestures that cause the issue and probably need to be fixed in a update.
so the choice is, use One UI if you want to use google gestures, if you want to run Nova or another launcher, stick to the buttons or samsung gestures?
Theot so the choice is, use One UI if you want to use google gestures, if you want to run Nova or another launcher, stick to the buttons or samsung gestures?
For now yes
Just an FYI. I'm Using Nova with One UI gestures Swipe up replaced the 3 icons at the bottom of the screen. Seems to be working fine.
