10-31-2020 09:32 AM
35 12
tools
  1. KPMcClave's Avatar
    Has anyone who monitors their battery use experienced an unusually high battery drain that when looking deeper (I use GSAM Battery Monitor Pro) appears to be due to the Video On usage line?
    I didn't have this issue on my Pixel 3 XL. I have seen mention of it here and there in a Google search, but nobody has given any sort of fix for it.
    Right now, it's my Twitter app that's the culprit. I've already uninstalled and reinstalled Twitter and the issue persists. I've toggled any app setting having to do with video.
    Instagram had been a problem in the same way. I uninstalled and reinstalled and that seemed to correct the issue in Instagram.
    My S20 FE has been off the charger for 2.5 hours and Twitter's Video On usage has been running for exactly as long. The app has eaten 61.6% of the overall apps' usage, with Android System a distant second at only 6.4%:
    The "Video On" Battery Leak-screenshot_20201011-102059_gsam-battery-monitor-pro.jpg
    The "Video On" Battery Leak-screenshot_20201011-102106_gsam-battery-monitor-pro.jpg
    The "Video On" Battery Leak-screenshot_20201011-102125_gsam-battery-monitor-pro.jpg
    I really don't want to have to use the Twitter mobile site in Chrome.
    Anyone aware of this issue (some say is a known one in Android 10) and have a fix?
    10-11-2020 10:31 AM
  2. B. Diddy's Avatar
    Does this also happen with the stable Twitter version? Do you customarily join beta programs wherever possible, and if so, are you also on the beta of Instagram?
    10-11-2020 01:01 PM
  3. KPMcClave's Avatar
    I just rolled back to stable Twitter, so we'll see.
    I am on the beta of Instagram, but I reinstalled the beta and that seemed to fix the issue.
    Yes, I do tend to use betas when possible.
    However, all that said, this issue didn't exist on my Pixel 3 XL, either with Andorid 10 (I saw this drain may be an issue in 10) or after I updated to 11 via betas and now stable release. That with all the same software, betas included, otherwise.
    10-11-2020 01:05 PM
  4. B. Diddy's Avatar
    Right, but it's a different device with different firmware, so I wouldn't be surprised if a beta caused problems on one device but not another.
    10-11-2020 01:18 PM
  5. KPMcClave's Avatar
    Sure, generally speaking, of course.
    That doesn't mean there might not be a fix out there. One of the search results I found last night was a Google forum, I believe. Meaning someone had the same issue on a Pixel of some sort, I'd guess. I didn't.
    10-11-2020 02:12 PM
  6. KPMcClave's Avatar
    The Video On line has started to rise again now with the stable version of the Twitter app. I did watch about 2 minutes of video or so between 2 vids, but the time for Video On is currently 10 minutes and 9 seconds.
    I'm going to charge back up to 100% and see what it all looks like.
    10-11-2020 03:04 PM
  7. B. Diddy's Avatar
    Hmm. Does this only happen after you've watched at least one video on Twitter? Or does it happen even without that?
    10-11-2020 04:07 PM
  8. KPMcClave's Avatar
    Even without.
    10-11-2020 04:22 PM
  9. B. Diddy's Avatar
    Try temporarily uninstalling all updates to Android System Webview -- the latest update seems to be causing other glitchiness with printing (at least on Samsung devices), so maybe it's causing this as well.
    10-11-2020 04:30 PM
  10. KPMcClave's Avatar
    Thanks. I'll give that a go. I think in one of the mentions of this issue I saw in the Google search Webview was mentioned.
    10-11-2020 08:01 PM
  11. Zolee10's Avatar
    I have same exact problem. With two other apps. It happens only when I watch a video inside of them. Hibernating, disabling nothing helps to stop "Video on" value and Power percentage they use from growing. Really weird.
    Nothing helps just restart
    Tried disabling android web view, doesnt help stoping this runaway train and it comes back on its own after restart.
    Samsung S20+, Android 10, OneUI 2.5
    KPMcClave likes this.
    10-15-2020 01:59 PM
  12. KPMcClave's Avatar
    Funny that you're posting this now, because I just went looking for this thread to circle back myself.
    I just noticed my Ring doorbell is the culprit of the day with this. Currently says Video On use is well over 3 hours. Ring has used over 30% of my apps' battery consumption. Ring is not a beta app.
    I had mentioned previously that I'd uninstalled and reinstalled the Instagram beta and it seemed to fix the issue...but not permanently. I reverted back to stable Instagram yesterday when I saw the beta was showing this battery issue again. We'll see if the stable version fixes the issue, but as Ring isn't a beta we can't blame the issue solely on beta software.
    I'm also on Android 10 with OneUI 2.5 on the Verizon S20 FE. I think this is an Android 10 issue.
    10-15-2020 02:39 PM
  13. Zolee10's Avatar
    It is affecting only the apps that are not video players but have in app video playback and obly when in app video playback was used. Like insta, facebook, news apps etc.
    10-16-2020 10:24 AM
  14. KPMcClave's Avatar
    I wasn't sure if I'd played video every time I saw the issue in various apps (I've seen it in Twitter, Instagram and Ring off the top of my head). However, I did wonder if having auto-play set (which it is by default in some apps) might also trigger the leak. Even if someone doesn't overtly press play on a vid.
    10-16-2020 11:42 AM
  15. Zolee10's Avatar
    I dont know about that. But I am just dissvovering that it is not just one app but any app that has in app videe playback. If I press play its done. Video on and Power used keeps growing.
    Nothing helps but restart.
    10-16-2020 11:46 AM
  16. KPMcClave's Avatar
    Yup.
    10-16-2020 11:58 AM
  17. KPMcClave's Avatar
    Yup.
    ...actually, I just checked on Twitter. I'd watched a few short videos this morning, and it's at only 8 minutes + Video On, which is roughly what I watched. It definitely hasn't continued to suck battery.
    So far today I don't have any apps with the Video On glitch.
    10-16-2020 12:14 PM
  18. Zolee10's Avatar
    Make sure that you manualy refresh gsam. You have to exit to the gsam main screen in order to do it. Then go back to application details.
    For one up disabling picture in picture permissio helped. For others didnt. I uninstaled android web view and chrome updates, same thing. Helped for some didnt for others.
    I wonder is this gsam (false report) or real android bug.
    10-16-2020 12:38 PM
  19. KPMcClave's Avatar
    I did refresh. Still no continued Viedo On drain for Twitter (this time) beyond video I actually viewed.
    I didn't have this issue at all on Android 10 (or after I upgraded to the betas and then stable Android 11) on my Pixel 3 XL. On the one hand you could say it didn't happen with Android 10 on the Pixel, but on the other it also didn't happen when viewing via Gsam on the Pixel.
    10-16-2020 01:01 PM
  20. mustang7757's Avatar
    Force stop Twitter , then check next charge cycle of its still high
    10-16-2020 01:04 PM
  21. Zolee10's Avatar
    His twiter app works fine.
    But, when some app starts behaving like this nothing but restart helps. Tried regular force close, then clearing cache & data. Then tried disabling from settings (put in deep sleep stock battery manager), hibernate by Greenify and finaly not even dissabling with CCSWE helps!!!
    It just continues sucking battery via some stuck video process.
    10-16-2020 04:42 PM
  22. KPMcClave's Avatar
    Twitter isn't misbehaving. It has in the past.
    It isn't only one app, nor is it consistently any app. Instagram, Twitter and Ring (and maybe others) have shown this Video On battery drain sometimes. There is no consistency to the leak.
    mustang7757 likes this.
    10-16-2020 04:45 PM
  23. mustang7757's Avatar
    Gotcha , you checked device care for any app crash reports?
    10-16-2020 04:49 PM
  24. KPMcClave's Avatar
    Nothing there.
    10-16-2020 05:14 PM
  25. mustang7757's Avatar
    Nothing there.
    Ok , how about recovery cache clear ?
    10-16-2020 05:29 PM
35 12
  1. Can I delete some files in Documents folder on my Android phone?
    Last Post: 10-12-2020, 03:33 PM
  2. why do I get "your .... will be install on your device soon" and nothing happens?
    Last Post: 10-11-2020, 09:56 AM
  3. unable to view sms messages on coolpad 3632A
    Last Post: 06-03-2019, 04:48 PM
  4. How to get to my music on the sd card
    By San42 in forum Ask a Question
    Last Post: 06-18-2017, 12:31 PM
  5. Battery drain on phone after gear update
    By MrSaturdaynite in forum Samsung Gear S2
    Last Post: 12-26-2015, 03:55 PM
