    I'm looking to replace my factory unlocked S9 with a used S20+. I have an almost 10 year old GUDP (Gradfauthered Unlimited Data Plan) from Verizon. Because my S9 is factory unlocked I can use my phone hotspot without it being blocked. I know that if I buy an factory unlocked S20+ this will work the same way. I wanted to know what might be the tradeoffs (if any) of someone's unlocked carrier phone (from AT&T, T Mobile, Boost, etc.) and then just flashed it to the phone I wanted.
    Questions:
    1. Is the phone hardware in the S20+ identical regardless of if you buy an unlocked phone from Samsung or a carrier phone from any of the carriers?
    2. If there is no difference in hardware, is there any reason not to just buy the cheapest S20+ you can find and flash it to the firmware you want?
    3. I want to be sure my Hotspot is not blocked by Verizon firmware. If I flash a Verizon phone to a Factory Unlocked firmware is there any reason the phone would know it was orginally a Verizon phone and block the hotspot from working.
    4. Has anyone tried doing this. I'm especially curious to hear from any of you who may have a Verizon GUDP who use there hotspot after flashing a verizon (or other carriers) phone.
    11-28-2020 10:22 AM
  2. mustang7757's Avatar
    1. They are identical for all
    2. Yeah if you like to find the cheapest, then flash will be ok.
    3.yes Verizon to factory unlock you can do
    4. I have done flashing between all carriers and unlocked no issues .
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply
    https://forums.androidcentral.com/sh...d.php?t=409154
    11-28-2020 11:36 AM
  1. android 8.1 go not working with 2 audio sources simultaneously
    By Soup42 in forum Legacy Android & Other OS's
    Last Post: 12-12-2020, 12:08 PM
  2. S20 Ultra to Note 20 Ultra upgrade worth it ?
    By Jesus Delgadillo in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 12-07-2020, 12:12 PM
  3. Question on adding weather widget
    By dougdraws in forum Android 10
    Last Post: 12-01-2020, 07:06 PM
  4. Ghost touches on touch screen *Fixed*
    By djeire84 in forum Sony Xperia 10
    Last Post: 11-29-2020, 07:46 AM
  5. My samsung SM-A507FN stuck on Odin Mode
    By Android Central Question in forum Samsung Galaxy A50
    Last Post: 11-28-2020, 01:30 PM
