S20 edge lighting is gone
DarthNutz
5
I have a Verizon S20 and I installed a system update two days ago and now there is no edge lighting. I called up Samsung support and they told me that it is no longer an option. Why would they digress their phones?
Welcome to Android Central! I moved this to the S20 forum for more specific traffic.
If you're on OneUI 3, then I believe it's been moved from display settings to notification settings.
I found it! It is now under notifications>Brief pop-up settings.
So stupid that they moved it away from the edge screen settings.
And if you choose the 'Detailed' popup versus 'Brief', edge lighting doesn't work at all.
Hopefully once Edge + is updated in Goodlock, you can still get edge lighting even with detailed popup. Screenshot_20201212-104522_Settings.jpegScreenshot_20201212-104527_Settings.jpeg
hiredbyskill
