New Samsung alert! Score a Galaxy S21 5G for as little as $99 right now
Extended battery life by almost double, and better privacy!
- I tried this suggestion from Sakitech after watching his Youtube video on it.
Honestly its genius and has made serious impacts on extending my battery life.
I am literally ending my day with 70%+ battery everyday!
Basically the trick is turning off location on your phone and creating a bixby routine to turn it back on when you open apps that need location (maps, waze, etc...), then the bixby routine turns location back off when you exit the phone.
Dont worry about not knowing what apps need location. When location is off and you open an app that needs it, the app will let you know. Then if you want to give it location permissions just go add it to the bixby routine.
Its a game changer!
What the video here if you are interested in trying it:
Rose4uKY likes this.01-14-2021 09:15 AMLike 1
- Forum
- Samsung Android Phones
- Samsung Galaxy S20 & S20+ & S20 Ultra
« [13/JAN/21] S20 FE 4/5G Global updates TL2/UA5 rolling out JAN: security patch + bug fixes
S20FE on T-Mobile or S20+ 5g on Google Fi »
