1. alarsen7's Avatar
    So I see that the samsung messages app shows support for chat features now on Verizon so my wife and I decided to go back to it since we used the chat features primarily for our chat. However even though it shows it's turned on it doesn't work. I don't get typing indicators or read receipts. I've cleared the cache and storage from the app. Does it take a while for it to fully authenticate and turn on?
    mlblack16 likes this.
    04-21-2021 06:18 PM
  2. mustang7757's Avatar
    Verizon possible didn't turn on from their end , they had this issue in past not sure it's been addressed by them , your on unlocked version or carrier the device?
    04-21-2021 07:42 PM
  3. alarsen7's Avatar
    I am on a carrier version S20+.
    04-21-2021 09:33 PM
  4. mustang7757's Avatar
    Have you tried the stock samsung message app?you can use Google message app as Samsung eventually going to it and has RCS
    04-21-2021 09:41 PM
  5. alarsen7's Avatar
    This is with the stock samsung messages app. RCS works in Google messages but my wife likes the samsung app better and I wanted RCS to work between us. So I am using the stock samsung app and get the notification that Chat features are now on samsung messages when launching the app and they are all on in settings for both of us. But no read indicators or typing indicators. I checked with Verizon and they said RCS is enabled I need to check with Samsung.
    04-22-2021 06:54 AM
  6. mustang7757's Avatar
    Samsung probably going push u to verizon because they are the ones responsible to enable . You can try clearing data then force stop the message app or try verizon messages plus app otherwise verizon didn't enable it yet.
    04-22-2021 09:28 AM
  7. alarsen7's Avatar
    Not going to use verizon messages plus app. I talked to verizon and they said it was enabled so they lied I guess or there is something else going on. I cleared the cache and data from the app.
    04-22-2021 10:44 AM
  8. mustang7757's Avatar
    I remember this being a issue on previous samsung phones , Im not sure they fixed it for verizon, going forward probably by next year or 2 tops we all going be using googles app as they collaborated together
    04-22-2021 11:09 AM
  9. mlblack16's Avatar
    Just a thought, but are you using a beta version of Google Messages? From what I read, Samsung will use Google's RCS services to achieve this, so I would think one will need to have carrier services and Google Messages installed, and if there's anything funky going on with the Messages/carrier services side of things, Samsung Messaging app would have issues.
    04-26-2021 09:11 AM
  10. alarsen7's Avatar
    So I am not using google messages at all right now. The other weird thing is it doesn't work between my wife and I. But we both have chat features working for her dad and sister in our samsung messages app. So it is working in some form just not between the two of us.
    04-26-2021 09:58 PM
  1. Replies: 5
    Last Post: 04-22-2021, 02:53 AM
  2. Messaging- dots by contacts name then disappears
    Last Post: 04-21-2021, 11:19 PM
  3. Mike on Google Chrome not responding
    By frank1492 in forum Samsung Galaxy Note 4
    Last Post: 04-21-2021, 11:15 PM
  4. I accidentally turn off my screen lock and now i cant turn it back on.
    Last Post: 04-21-2021, 11:14 PM
  5. Samsung phone
    By Jockyspider in forum More Samsung Phones
    Last Post: 04-21-2021, 05:41 PM
