1. YuanhaoYoung's Avatar
    Hi all,
    I'm running an S20 FE with the June update. The update was a few weeks ago, and everything's been going well until 2 days ago. I noticed that the battery was draining faster than usual, and when I checked, saw that CameraLightSensor was using the most battery. It always show 0 minutes active, but as of now, 22 hours in the background.
    I haven't installed any new apps or made any changes to settings. What can be doing this? Can it be some new version of Google Play Services or something?
    07-01-2021 05:45 PM
  2. B. Diddy's Avatar
    Does this help? https://r2.community.samsung.com/t5/...n/td-p/4612333
    mustang7757 likes this.
    07-01-2021 06:01 PM
  3. mustang7757's Avatar
    Never heard of this , try clearing data and force stop the camera app
    07-01-2021 06:13 PM
  4. YuanhaoYoung's Avatar
    I think so. I'll see. For some reason, in Advanced Settings->Motions and gestures, the "Mute with gesture" was turned on, even though I don't remember doing that. From the description, it sounds like it would use the light sensor. I turned it off now, so let's see if that does the trick.
    B. Diddy likes this.
    07-01-2021 07:47 PM
  5. YuanhaoYoung's Avatar
    Well, for a few hours, it looked like turning off "Mute with gestures" worked, but it's back. 8.8% of battery used by camera light sensor today. I've reset the camera settings, and I've forced stopped it now, so I'll see how that works out.
    07-02-2021 07:11 PM
  6. B. Diddy's Avatar
    What about pocket mode -- is that on?
    07-02-2021 07:31 PM
  7. mustang7757's Avatar
    Cool just remember watch battery stats after full charge .
    07-02-2021 08:41 PM
  8. YuanhaoYoung's Avatar
    Simply resetting camera settings didn't help. After I cleared all its data, the problem seems to have gone away. But it's annoying that this is the second time I've run into settings/data problems with the camera. The first time, I had to reset settings to fix laggy shutter button, and now to fix a battery draining issue. I have to wonder what's next.
    Anyway, thanks to all who helped!
    07-06-2021 08:12 PM
  9. mustang7757's Avatar
    Hopefully gets addressed in future updates
    07-06-2021 08:51 PM
  1. fesbook Now from popping up every time I unlock my phone? Recover
    Last Post: 07-01-2021, 01:23 PM
  2. What google account is used when the android phone is powered on ?
    By JustRay in forum Samsung Galaxy S10 & S10+
    Last Post: 06-30-2021, 01:25 PM
  3. Replies: 2
    Last Post: 06-30-2021, 01:08 PM
  4. Problem signing up to website
    By Android Central Question in forum Site Feedback & Help
    Last Post: 06-30-2021, 10:33 AM
  5. Can you use emojis to name your Photo Albums?
    Last Post: 06-30-2021, 10:27 AM
