S20 plus screenshot will not save
Theot
1,499
3
So the past couple weeks my S20 plus has not been saving screenshots. It will flash like it's taking one then as soon as you try to do anything on the toolbar with it, save, edit, share etc it just disappears and there is no screenshot saved. I turned off the toolbar and it still flashes like it's taking one but never saves anything. Turned off the palm swipe (never use it anyway, all it does is trigger the back gesture for me) and still nothing. Anybody ever experienced this or have an idea how to fix it? I never thought I'd need it this much but it turns out I apparently use it a lot. Thanks in advance.
Theot
1,499
3
No, nothing
Figured it out. I put a .nomedia file in my screenshot folder. That wouldn't let it work.
So how do I keep Google photos from backing up screenshots? I surely don't need most of them backed up with my pictures.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,575
6,162
113
You would have to turn off back up and sync in Google p
Akshay
