1. Borgie's Avatar
    Is there a big difference between this and the 9W fast charge ones? I see there are two available from Samsung (a stand for 80 bucks and the duo pad for 100). Looking to maybe get one along with my Buds+ with my 200.00 credit.
    Are there any 3rd party 15W wireless chargers that nyone has used that you don't have to worry about burning up?
    02-29-2020 08:29 AM
  2. arunma's Avatar
    I don't think you need to worry about safety with the 3rd party chargers, but most I've seen on Amazon will deliver only 9 W to the Note 10+ (and presumably S20 too) despite being rated at 15 W. You can usually check this by looking at the description and searching for supported devices. The only charger that actually delivers 15 W to Samsung phones is the Samsung 15 W charging stand.
    I've been looking for alternatives since I want a pad. I have the stand and use it at home, but it's not convenient for travel.
    Borgie likes this.
    02-29-2020 09:17 AM
  3. j_hansen's Avatar
    For 3rd party chargers you can't go wrong with Aukey or Anker.
    Aukey is doing this really nice 15W wireless one
    https://www.amazon.com/AUKEY-Wireles...cUvbUpU6749011
    Borgie likes this.
    02-29-2020 02:53 PM
  1. Note 10 won't wireless charge in car
    By Kynisen in forum General Help and How To
    Last Post: 02-28-2020, 03:47 PM
  2. Note10 - Fast wireless charging not working while connected to the included AKG USB-C earphones
    By Andrei_Andrei in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 02-28-2020, 04:21 AM
  3. Phone lights up every few minutes when charging
    Last Post: 02-27-2020, 07:46 PM
  4. Could a phone w/ removable battery have wireless charging/IP68?
    Last Post: 02-26-2020, 09:32 PM
  5. Why is the fast charging function greyed out in my settings?
    Last Post: 02-26-2020, 09:02 PM
