1. rflores5432's Avatar
    I have fingerprint and face unlock set up. With my ultra, whenever it sits untouched for several hours, especially overnight, it always makes me swipe to unlock and use my pin rather than give me the option for fingerprint or face scan. Not sure if I have something set up wrong or if this is the way it is now. With my S9+, it would never ask this unless the phone was restarted.
    03-25-2020 07:55 AM
  2. rflores5432's Avatar
    Wowz just noticed someone else asked about this same exact question a couple hours hour. What are the chances? Sorry for posting about this again. I received my answers from. The other post.
    03-25-2020 08:16 AM
  3. B. Diddy's Avatar
    You may not have seen my response there either -- check to see if your phone is doing a scheduled restart every night: https://thecellguide.com/schedule-au...laxy-s20-13176
    03-25-2020 12:49 PM
  4. mustang7757's Avatar
    This is normal andriod security feature that cant be disabled and happens at certain times especially you leave it untouched for more then few hours .
    nuangel2 likes this.
    03-25-2020 12:56 PM
  5. bhatech's Avatar
    See the disclaimer when you go into security and biometric section
    mustang7757 likes this.
    03-25-2020 01:31 PM
  6. mustang7757's Avatar
    See the disclaimer when you go into security and biometric section[IMG=1079x2288]https://uploads.tapatalk-cdn.com/20200325/b80f224de14685855bbc2b2a6fe69d7e.jpg[/url]
    Nice find on the disclaimer
    bhatech likes this.
    03-25-2020 01:33 PM
  1. How to Change SD Cards?
    By RonRock in forum Ask a Question
    Last Post: 03-31-2020, 09:32 AM
  2. How can I get MMS to start sending pics ?
    By Rocky Dodaday in forum Legacy Android & Other OS's
    Last Post: 03-25-2020, 04:08 AM
  3. How to flash Open Gapps zip
    By Juif in forum Ask a Question
    Last Post: 03-24-2020, 04:32 PM
  4. Replies: 2
    Last Post: 03-24-2020, 11:51 AM
  5. CTS and GTS - How to map failed tests
    By Tuga1978 in forum General Help and How To
    Last Post: 03-24-2020, 06:45 AM
