04-23-2020 02:14 PM
31 12
tools
    Hi friends , just now I'm using my S20Ultra to playing some games, but it is happening when I'm using the 120hz display, whatever games I open, the screen will become yellowish, but in the 60hz screen, it is fine for everything. Sometimes the display turn to yellowish when I just switch to 120hz. Need help.
    04-15-2020 04:20 AM
  2. mustang7757's Avatar
    Maybe a bug , can see if other members have this issue also.
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.
    https://forums.androidcentral.com/sh...d.php?t=409154
    iamKai07 likes this.
    04-15-2020 09:41 AM
  3. mustang7757's Avatar
    [Moved to s20 forums]
    04-15-2020 09:42 AM
  4. iamKai07's Avatar
    04-15-2020 10:44 AM
  5. mustang7757's Avatar
    [Merged duplicates]
    04-15-2020 10:53 AM
  6. mustang7757's Avatar
    Hello, welcome !
    No need to make another post as I put you in the correct forum already .
    04-15-2020 10:54 AM
  7. iamKai07's Avatar
    Oops didn't know that, Thanks for your help.
    mustang7757 likes this.
    04-15-2020 11:00 AM
  8. donm527's Avatar
    What game is it? Maybe an issue with game since maybe possible some games don't play nice with 120hz like in example below mentioning game called Subway Surfers.
    https://us.community.samsung.com/t5/...z/td-p/1148744
    mustang7757 and iamKai07 like this.
    04-15-2020 11:11 AM
  9. RustyFJ's Avatar
    I was watching a YouTube video and noticed the same issue - its a greenish overlay. Reported on Sammobile - https://www.sammobile.com/news/galax...nt-on-display/
    04-15-2020 11:16 AM
  10. iamKai07's Avatar
    Hi I think this the the problem that I facing, also my device come with the Exynos processor. And yes, that tint gone when I turn the screen brighter.
    04-15-2020 11:26 AM
  11. dgcorn's Avatar
    Yellowish sounds like the blue light filter. Not sure why that would engage with game play, but you might check the the display setting.
    04-15-2020 01:17 PM
  12. Peter Scooze's Avatar
    Ive read its a possible issue after the April security patch with the exynos version.
    04-15-2020 01:46 PM
  13. criminal_bg's Avatar
    it is an issue with the latest update (april security), which seems only to affect the exynos version of the Ultra. Samsung hasnt been doing too good with updates recently, causing more problems than resolving them.
    04-16-2020 09:47 AM
  14. mustang7757's Avatar
    This with Exynos chip the issue
    04-16-2020 11:43 AM
  15. iamKai07's Avatar
    Yea, I'm now a bit disappointed about this.
    04-16-2020 12:14 PM
  16. mustang7757's Avatar
    Hopefully they fix this in the next update
    04-16-2020 12:14 PM
  17. Peter Scooze's Avatar
    Supposedly a factory reset will fix it
    04-16-2020 12:35 PM
  18. criminal_bg's Avatar
    based on what i read that doesnt always work, samsung said clear cache as well but again does not always work, so it might need an update to fix the issue from an update.
    04-16-2020 01:00 PM
  19. Peter Scooze's Avatar
    https://www.sammobile.com/news/samsu...ftware-update/
    04-17-2020 04:41 PM
  20. iamKai07's Avatar
    Thanks for the sharing.
    04-18-2020 02:21 AM
  21. donm527's Avatar
    04-19-2020 09:31 AM
  22. Mike Dee's Avatar
    I haven't had any issues caused by updates on the S10+, Note10+ or S20 Ultra. All snapdragons.
    04-19-2020 09:55 AM
  23. criminal_bg's Avatar
    but Mike, you said, you hav the SD versions, this green screen issues as i said was hitting exynos versions.
    none the less, the S20 Ultra has gone from focus issues, which some would tell you took 2 updates to get fixed, to now this green screen issue when your Ultra overheats or battery is low, among other factors, is the Ultra so much of a different build to the S20+ that makes it susceptible to these things.
    04-20-2020 07:43 AM
  24. Mike Dee's Avatar
    I was referring to the updates in general
    04-20-2020 09:15 AM
  25. Peter Scooze's Avatar
    https://www.sammobile.com/news/samsu...w-rolling-out/
    04-22-2020 06:11 AM
31 12
  1. How do you hold your S20
    By customshopkv1 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 05-13-2020, 10:53 AM
  2. Do you have/did you have an ultra and move to a s20+?
    By AlphaBeepBeep in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 05-05-2020, 03:15 PM
  3. S20 mms fails to load while on WiFi
    By mcaspe1 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 04-14-2020, 11:04 PM
  4. What are some of the best cases for protecting my S20?
    Last Post: 04-14-2020, 10:43 AM
  5. Problém with brightnesss
    Last Post: 04-13-2020, 09:58 PM
