02-10-2021 05:49 AM
60 123
tools
  1. cpcxgsr's Avatar
    I too went from s10 to s20/21. I've noticed my battery on the s10 to be "better" than on the 20/21.
    Even with the bigger battery, battery didn't last as long as the 10. My theory is because the 20/21 are 5g phones.
    I'm on VZW. unfortunately I cannot turn off my 5g signal
    02-05-2021 12:17 PM
  2. chimpboy74's Avatar
    Is 5g a battery drain even if no 5g signal? I don't have 5g at home and Don't think I'll be able to make use of 5g until I can travel again so would probably turn off to add even more battery life!
    02-05-2021 12:25 PM
  3. soundchasr's Avatar
    I'm on Verizon too. Anyone figures out how to turn it off, let me know!
    02-05-2021 12:31 PM
  4. cpcxgsr's Avatar
    I could be wrong, but with the 5g being enabled, it's constantly searching for 5g/UWB signal. Hence the less than stellar battery life.
    I'm on vzw's 5g UWB service. My phone constantly searches for 5g signal. Switching from 4g to 5g.
    I don't think VZW allows you to switch over to 4g only. At least I couldn't find that option under networks.
    02-05-2021 12:55 PM
  5. ironass's Avatar
    I have a 5G plan on EE on SIM #1 and although I cannot receive 5G at home yet, I leave it enabled for travelling. My 2nd SIM is GiffGaff and not on a 5G plan and that is switched to LTE. I do not notice any undue battery drain by using the 5G option on EE.
    02-05-2021 03:01 PM
  6. chimpboy74's Avatar
    Yeah my situation is same (I'm on Vodafone though) and 5g is unlikely at my home address for the foreseeable future.
    I thought about turning off 5g to save battery but in all honesty I'm impressed with battery life already. Plus I'll probably forget to turn it back on when I'm travelling!!
    ironass likes this.
    02-05-2021 03:19 PM
  7. Blinkinek's Avatar
    Coming from the S10 to the regular S21 I am noticing a huge difference in battery life. On the S10 it estimated almost 18hrs of battery life where the S21 is estimating only 10hrs. I notice the difference too. Just from light browsing I can see the battery percentage go down by 1% every other minute or so. Even after 2 years with the S10 my battery would last until 5 or 6pm.
    Shouldn't I be getting better battery life with this display? I checked all settings and everything is set up the same as my old phone.
    Another thing is the S21 doesn't charge nearly as fast as the S10 does.
    Exactly same problem here with S21 Exynos.
    02-08-2021 03:27 AM
  8. cohoman's Avatar
    I also switched from an S10 to the S21, and below is my S21 battery status. It shows 22 hours of battery time after a full charge based on my daily usage.
    Granted, because of the COVID lockdown I haven't traveled much away from my home, so maybe that is affecting my battery usage?
    02-08-2021 07:02 AM
  9. X1tymez's Avatar
    Here's my S21+
    02-08-2021 02:55 PM
  10. Notefan161's Avatar
    exynos users is 5-6 screen time about the average or is it more?
    02-10-2021 05:49 AM
60 123
  1. Battery life after a 6-12 months?
    By Tmel14 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 07-02-2021, 10:28 AM
  2. Battery Results out from Tom's Guide!!! S20 Ultra 👑 beats out the S21 Ultra
    By corvette72778 in forum Samsung Galaxy S21 & S21+ & S21 Ultra
    Last Post: 01-27-2021, 05:54 PM
  3. Why is google chrome draining so much battery?
    By BDBB in forum Ask a Question
    Last Post: 01-27-2021, 04:19 PM
  4. galaxy buds battery question
    By ansa82 in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 01-27-2021, 09:52 AM
  5. How do I turn on low battery warning notification android 8.1
    Last Post: 01-23-2021, 03:29 AM
