ThrottleJohnny
Trusted Member
And that's why posting some stupid battery test video, and then declaring the s21 battery to not be worth the upgrade was trash. Give me REAL user data!
It's still early days for me but days 1 and 2 I was a bit Concerned that battery life wasn't as good as I hoped. Today seems much better.
How much is due to me not fiddling with it as much is hard to say!!!
I upgraded from the S10 to the S21 and the battery life was a disappointment initially. However, after a week or so in, it seems to be much better. I did a couple cycles of using the phone until 0%, then charging it to 100%. It helps to break the battery in a bit.
Is 5g a battery drain even if no 5g signal? I don't have 5g at home and Don't think I'll be able to make use of 5g until I can travel again so would probably turn off to add even more battery life!
Coming from the S10 to the regular S21 I am noticing a huge difference in battery life. On the S10 it estimated almost 18hrs of battery life where the S21 is estimating only 10hrs. I notice the difference too. Just from light browsing I can see the battery percentage go down by 1% every other minute or so. Even after 2 years with the S10 my battery would last until 5 or 6pm.
Shouldn't I be getting better battery life with this display? I checked all settings and everything is set up the same as my old phone.
Another thing is the S21 doesn't charge nearly as fast as the S10 does.
