Word is that Samsung actually noted on the peel-off sticker on the screen which hole to poke on the bottom in order to access the SIM tray. I guess they needed a notation on that to not poke the ones on the top too!you may have poked a SIM key into a microphone aperture.
Yes, you may have poked a SIM key into a microphone aperture. Test whether the ambient noise cancellation is still working.
It was quite ambiguous to see on the black phone.
This a schematic for s21 , 2 holes for microphone seriesView attachment 331941
According to that picture no mic , do you see one on yours?Isn't there actually 3 things at the bottom? Sim tray, mic, and usb port. And that card shows 2.
I think your going be fine if those things are working. Your welcome!Thank you Mustang. I hope I didn't damage anything. I tested the ANC and pro video. they sounded normal. Fingers crossed.
but the Sim card pin did penetrate about 0.5 cm...
Yes, on the bottom there is a sim tray, mic and usb-c port.According to that picture no mic , do you see one on yours?
I see that too, right next to the usb port. That made me nervous as it was so close to the sim tray.
Yes I see that from the second picture I posted where they show front and back of the device.Yes, on the bottom there is a sim tray, mic and usb-c port.
