I have had my s21+ for 4 days now and I'm wondering if I should return for the ultra. I have pretty small hands but I'm wondering if the screen resolution and Camara is worth it. What do you all think?
What's the difference in resolution. Will it really be that noticable?I have had my s21+ for 4 days now and I'm wondering if I should return for the ultra. I have pretty small hands but I'm wondering if the screen resolution and Camara is worth it. What do you all think?
I had the Plus for one or two days, and exchanged it for the Ultra. LOVE the ultra.I have had my s21+ for 4 days now and I'm wondering if I should return for the ultra. I have pretty small hands but I'm wondering if the screen resolution and Camara is worth it. What do you all think?
The difference in resolution is that the Ultra displays 78% more detail. That's noticeable to some people and not to others, depending on eyesight, what's being displayed, and other factors. OP won't know whether it's noticeable to them just by asking which other people do or don't notice it.What's the difference in resolution[?] Will it really be that notic[e]able?
Ok. Don't think it will be noticable enough for the extra doughThe difference in resolution is that the Ultra displays 78% more detail. That's noticeable to some people and not to others, depending on eyesight, what's being displayed, and other factors. OP won't know whether it's noticeable to them just by asking which other people do or don't notice it.
Again, that's different for different people. For many of us, the sharper resolution (among other features) is enough to justify the extra cost; for many others, it isn't. There's no universally right or wrong answer.Ok. Don't think it will be notic[e]able enough for the extra dough
The Ultra also has S Pen support, for those who like that sort of thing.For me the better screen, more ram, bigger battery and better cameras was worth it.
Yup, I get that. For my needs it won't matterAgain, that's different for different people. For many of us, the sharper resolution (among other features) is enough to justify the extra cost; for many others, it isn't. There's no universally right or wrong answer.
If the Spen would have been built in then maybe that would have drawn my interest. Separate for "me" is a no goThe Ultra also has S Pen support, for those who like that sort of thing.
Yeah, it's a matter of opinion for everyone, get what works for you. I don't see anything that makes the ultra better for me, the camera, I don't care about the extra features, not much bigger battery, getting the 256 so the 512 is useless for me, over 5yeare with the S7 and only have 20 gigs on it, 3 on the SD card. Anything will be better resolution over the S7, don't see it, won't know what the resolution means on the ultra.I would say get the ultra while you can. Else it would be late. Whatever the plus got, ultra has it much better. Small hands are fine, i had Pixel 5 before this, that had the best form factor and size for small hands like mine. But after switching to S21 Ultra, I don't find it any difficult. Get a silicone case or something to get a better grip and less chance of slipping out of small hands.
Correct, if it is me, i will spend a few more bucks and get the best. For some, The S21 plus would suffice, so that's okay as well. But incase OP wants to switch, better do that while the remorse period is up.Yeah, it's a matter of opinion for everyone, get what works for you. I don't see anything that makes the ultra better for me, the camera, I don't care about the extra features, not much bigger battery, getting the 256 so the 512 is useless for me, over 5yeare with the S7 and only have 20 gigs on it, 3 on the SD card. Anything will be better resolution over the S7, don't see it, won't know what the resolution means on the ultra.
It does boil down to what you want and use the phone for. Now if I can get one without the front camera, I don't need to do silly selfies to do the look at me look at me.
The options are all laid out there that's for sure. Again, everyone is different. If someone has lived with a S7 for for 5 years I'm sure even the s21 would be a great upgrade, they aren't to concerned with the best,,Correct, if it is me, i will spend a few more bucks and get the best. For some, The S21 plus would suffice, so that's okay as well. But incase OP wants to switch, better do that while the remorse period is up.
