1. Cool Jeff's Avatar
    Hi
    As the cable that comes with the s21 ultra is type C on both ends, can you use any good USB cable type C to type A for AA in your car with the s21 ultra or you need a samsung one?
    I have an extra Oneplus cable, should it works?
    03-30-2021 01:59 PM
  2. danhartman26's Avatar
    Hi
    Any good cable should work fine. We use some Anker cables with our Note 20 Ultras. Just try the cable you have, and if it works, great!
    If it doesn't work, I'm sure most decent cables will be fine. I would recommend Anker cables - I have many USB C to C, C to A, A to micro USB - Yes, unfortunately I still have devices that use micro USB: -(
    03-30-2021 07:37 PM
  1. Good news for T-Mobile customers who are also Google fans!
    By B. Diddy in forum General Carrier Discussion
    Last Post: 04-01-2021, 09:25 PM
  2. Replies: 4
    Last Post: 03-31-2021, 07:18 PM
