1. kolyan2k's Avatar
    So I've been trying to use Link To Windows feature and everything works except for calls. I simply can't pair S21 to my new and fully updated Dell XPS. Anyone has issues or tips how to do this Bluetooth pairing? My Galaxy Buds paired just fine, phone gets pairing code from PC but nothing happens after I hit PAIR.
    04-24-2021 02:19 AM
  2. bill-e's Avatar
    Did you hit PAIR on both the phone and PC?
    04-24-2021 09:59 PM
  3. Justafyle's Avatar
    does your. pc have Bluetooth?
    04-24-2021 11:23 PM
  4. lattemaker's Avatar
    This post is deja vu for me. I just purchase and received a Dell XPS 13(9310) a couple of days ago and I have an S21 Ultra as well. I tried to get it to connect to Dell Connect and it was really difficult. Basically, I just kept trying and eventually restarted both my phone and computer and then it worked. In the middle of that I tried connecting to the Companion Phone app that is made by Microsoft and is a default app with Windows 10 and that paired up and synced on the first attempt. So I guess my advice to you is to make sure your phone didn't pair to your computer and if it did unpair it. Then restart both your phone and computer and see if that works. Like I said above I must have tried 10-15 times to get it to pair to the computer and sync with the app before I got it to work.
    04-25-2021 12:06 PM
  5. kolyan2k's Avatar
    It shows up on my phone and I hit pair, but nothing shows up on PC. Dell can see my phone fine and PC shows up on my phone
    04-25-2021 03:16 PM
  6. kolyan2k's Avatar
    Thanks. Will try when I have free time. It also got some updates recently, maybe that did something
    04-25-2021 03:18 PM
  1. I want to factory reset my phone
    Last Post: 04-24-2021, 04:55 PM
  2. Why am i not able to connect my galaxy s8 to the screen in my car
    Last Post: 04-24-2021, 04:54 PM
  3. why is it showing me Download Pending if I want to donwload anything?
    Last Post: 04-24-2021, 04:31 PM
  4. Replies: 0
    Last Post: 04-24-2021, 01:05 AM
  5. What does the T logo with 4 dashes to the left of it mean
    Last Post: 04-23-2021, 09:29 PM
