1. digitaldawg1's Avatar
    I experience problems using Rode Wireless Go II mic receiver connecting straight USBC to USBC on the phone. System designed for this.
    But clipping, distortion, and terrible sound are the result. Called Rode and they report that the S21Ultra (specificially, not other Samsung models) has problems with external mic not only with Rode but with other brands also. They think that it has to do with the high resolution the Ultra is designed to receive versus whatever is sent from external mic sources.
    I am discouraged because I specifically purchased the Rode Wireless GO II system to be able to record good audio, especially at any distance, that cannot be recorded without many undesired effects from the native mic on the Samsung.
    Anyone know If this is being looked at by Samsung? (Rode says that the correction has to be from Samsung end, not the mic manufacturers).
    04-30-2021 02:34 PM
  2. Kizzy Catwoman's Avatar
    Not heard of this issue before. If you want to speak to Samsung directly it is best to flag the issue in the community forum of the Samsung Members app. Samsung moderators look in there. You can also file a bug report.
    04-30-2021 05:54 PM
  3. mustang7757's Avatar
    Try developer setting , think something u can tweak there
    05-01-2021 12:59 AM
  4. Alan Chan HK's Avatar
    12-03-2021 03:01 AM
  5. Alan Chan HK's Avatar
    Hi digitaldawg1,
    I experienced the same problem. I reported to RODE and went through a number of tests. They told me that the popping noise is due to my S21 ultra's sampling rate. I tested recording on other devices such as an old LG smart phone with USB-C, and my notebook with USB-C port recognizing RODE TR. I have no idea how to twist S21, such as changing sampling rate or other possible adjustment, to make it works.
    Please echo here if anyone got a solution.
    Many thanks.
    12-03-2021 03:04 AM
  1. Apps setting changed on samsun s21 ultra + android add on to apps i have not authorised
    By Android Central Question in forum Samsung Galaxy S21 & S21+ & S21 Ultra
    Last Post: 04-30-2021, 11:48 PM
  2. Can Galaxy S9 force touch button be remapped for other actions?
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 04-30-2021, 07:31 PM
  3. S21 Ultra Snapdragon in other Regions
    By Niv77 in forum Samsung Galaxy S21 & S21+ & S21 Ultra
    Last Post: 04-30-2021, 06:12 PM
  4. Can Galaxy S9 force touch button be remapped for other actions?
    Last Post: 04-30-2021, 12:11 PM
  5. Can Galaxy S9 force touch button be remapped for other actions?
    Last Post: 04-30-2021, 09:00 AM
