05-31-2021 12:48 PM
28 12
tools
  1. rimz808's Avatar
    I decided to give Samsung phone another try. Got the S21 Ultra and I have noticed that on this phone, like all my previous Samsung phones, whenever the battery is at 100%, it drops within just 2-3 minutes of normal use. Not that it is a problem, but other Android phones that I have used in the past, Huawei, pixel, oneplus, at least stay on 100% for at least over 15 minutes of use.
    Is this just the way Samsung handles its battery? Do other users notice this as well?
    BigDisplay likes this.
    05-10-2021 02:03 PM
  2. B. Diddy's Avatar
    I've always noticed that behavior on all of my phones, and I've had Pixels since the 1st gen.
    J Dubbs likes this.
    05-10-2021 02:17 PM
  3. felloffthetruck's Avatar
    Yea, not like the iPhone that stays on 100% for most of the day after a charge.
    05-10-2021 02:58 PM
  4. jweimn's Avatar
    That's fairly normal, just cause it drops to 99% fast doesn't mean the battery is messed up, I'd be more concerned if the phone was dying in under a day not whether it stays at 100 percent for awhile.
    SeanD_Colorado and Mooncatt like this.
    05-10-2021 03:56 PM
  5. rimz808's Avatar
    Thanks. As I thought. But just notice that it happens moreso on Samsung Phones and not other ones that I have had. Battery so far has been lasting me.
    Was just wondering if others do notice that as well on their phones.
    05-10-2021 04:27 PM
  6. jweimn's Avatar
    Also the other thing I forgot to mention is the battery indicator is different depending on the manufacturer like Apple will stay at 100 percent but the battery is at a lower state of charge than samsungs 99 percent
    JHStewart1023 likes this.
    05-10-2021 04:45 PM
  7. Roadijeff's Avatar
    The battery indicator on my S21 Ultra drops from 100% to 99% within a minute or two after I take it off the charger. However, I usually get 2-3 days of use out of it before charging again. My wife's iPhone 12 Pro gets put on the charger every night.
    05-10-2021 07:59 PM
  8. rimz808's Avatar
    I guess I just do not trust it enough to try to go 2-3 days without charging it. I get low battery anxiety. On average, at the end of my 8 hours workday my percentage is at 70%, having use my phone throughout the workday. I am usually around 50-40% by the time I go to bed. I then leave it on during the night so that it drains a bit so I then quickly charge it back up to 100% in the morning before I go to work.
    What does your average day time %?
    What are others charging routines? I always feel like I have to start the day off with 100%
    05-10-2021 08:08 PM
  9. mustang7757's Avatar
    Yeah normal on Samsungs , one plus and pixels little longer
    05-10-2021 08:45 PM
  10. mach1man's Avatar
    Yeah this is something I’ve noticed as well. So I turned the battery percentage off and haven’t looked back since
    Blaalad12 and Revak like this.
    05-10-2021 09:06 PM
  11. rimz808's Avatar
    Smart idea! I'll try that and see if it helps with my low battery anxiety
    mach1man likes this.
    05-10-2021 09:51 PM
  12. ssj100's Avatar
    It's actually something I've only noticed on the S21 Ultra. Although I've only owned two previous Samsungs before - S7 and S9+. Both these devices tended to drop from 100% to 99% (in standby with AOD always enabled) after 30-60 minutes. With the S21 Ultra, it only takes more like 10-20 minutes. Subsequently though (in standby with AOD always enabled), it tends to take the usual 30-60 minutes to drop 1% point.
    So yes, I've noticed it drop from 100% to 99% much faster than even previous models of Samsungs.
    05-11-2021 12:09 AM
  13. bhatech's Avatar
    Same here, have not used battery percentage for years now on all my phones and never missed it. I don't need to know the exact percentage at all times and increase anxiety
    05-11-2021 01:44 AM
  14. cknobman's Avatar
    Well when not on a charger the battery will drain.
    Dont focus on a few percentage points, focus on how long you get out of a charge.
    05-11-2021 08:43 AM
  15. Gayle Lynn's Avatar
    My older Galaxy phones starting 10 years ago up would generally drop 10% in an hour of use. I don't watch it like a hawk anymore, seems S21/S21U are fine.
    It was the battery usage that chose to buy an IPhone - and it was slower drain.
    At least the Galaxy will alert me of high background usage as it did with Google Photos recently, which I uninstalled as don't use it. And I tend to disable a number of apps - Chrome, Bixby, and now at least Facebook can be uninstalled but I disable FB services.
    Having watch, buds, VPN, AdGuard Pro probably contribute.
    I assume, you wake up a system it's going to be busy loading services and refreshing as it checks for updates.
    05-11-2021 08:48 AM
  16. Revak's Avatar
    Yes, the first 10% of the battery drains faster than the rest (especially the first 2%).
    05-11-2021 09:58 AM
  17. chimpboy74's Avatar
    I noticed after the last update a slightly faster battery drain. But it was consistent not just after taking off charge. Couldn't track it down to anything suspect. I just noticed I wasn't getting the usual times between charges with no change in my usage. Hoping the next update goes back to how it was.
    05-11-2021 12:18 PM
  18. Gayle Lynn's Avatar
    After updates it is normal for there to be more processing going on, yes? and clear the cache partition, see if that helps - it often does.
    05-11-2021 02:09 PM
  19. bxrider117's Avatar
    I would not let the fact that the battery prevent drops quickly on the S21 Ultra tarnish how good the phone is. I've had this phone for about a week. This is my latest battery stats
    Rose4uKY and SeanD_Colorado like this.
    05-11-2021 06:45 PM
  20. chimpboy74's Avatar
    Based on recent usage a full charge is getting me 21h
    05-12-2021 01:56 AM
  21. chimpboy74's Avatar
    I just got the update last night so dis that. Cleared the cache as you said and fully charged. Let's see if its improved today.
    05-13-2021 01:50 AM
  22. BigDisplay's Avatar
    It's the same for me.
    My former Mate 20X was on 100% for a long time in the beginning of a day, I always spend minimum 1 hour in the morning drinking coffee and checking my mail etc on my phone and still my Mate was on 100% after, but not with my S21u...
    05-13-2021 02:55 AM
  23. chimpboy74's Avatar
    I did the update and cleared the cache. Does seem better. Didn't need to charge it last night and probably won't need to for another 2 or three hours
    So I think it's better.
    05-14-2021 04:39 AM
  24. fuzzylumpkin's Avatar
    From reading this thread, I'm getting the impression that people would rather a battery indicator reassuringly lie to them than try to be accurate... Odd.
    05-14-2021 07:30 AM
  25. Roadijeff's Avatar
    All I know is if my battery drops below 25% charge my Allstate Drivewise app stops recording trips toward a 15% discount off my auto policy. A full charge on my S21 Ultra usually lasts at least 2.5 days before it drops to that level.
    05-14-2021 12:40 PM
28 12
  1. How to block an app from your Google Play Store
    Last Post: 05-10-2021, 11:43 PM
  2. How do I stop my music from changing by its self
    Last Post: 05-10-2021, 08:25 AM
  3. Blu Vivo XL5, unable to stop phone from sleeping apps
    Last Post: 05-09-2021, 06:57 PM
  4. How to stop massages from nvm
    Last Post: 05-09-2021, 05:46 PM
  5. why cant i download photos and videos from google
    Last Post: 05-09-2021, 11:24 AM
