06-12-2021 02:18 PM
36 12
tools
  1. mgbosshogg's Avatar
    Speaking of Bixby I never used it on my last Samsung nor have I used it on this new Ultra. Main reason. I'm confused by it. Is it really something I should be using or is it mostly a gimmick?
    There are 2 parts to it. Yes, it's a digital assistant like Google assistant et al. But that was never really meant to be it's main function. It is brilliant at controlling your actual phone and any connected devices.
    Unfortunately it was marketed as being the first so has always been dismissed.
    I love the routines. Makes it really hard to use a device without it. Yes there are 3rd party alternatives like ITTT , but none as integrated.
    Simple things like having no need for mobile data, location services, Bluetooth and phone locked whist in my own house.
    And the opposite when in my car..... You get the idea.
    06-06-2021 05:58 AM
  2. gomezz's Avatar
    Have now realised that I can now do without Smart Lock altogether given the Bixby routine to keep the phone unlocked when connected to my home wi-fi. Very rarely do I need to have the phone locked at home and better to have the phone locked while out and about even if (especially if) listening to something over a Bluetooth device with the phone in my pocket where it has proven to be susceptible to pocket surfing with Accidental Touch Protection not doing its job. Jury still out on car radio actually but I usually queue a playlist of sufficient length to cover the planned journey and never make or answer calls while driving - car radio controls can be used for that if absolutely necessary.
    Adjusted the screen timeout to 15 seconds and the screen lock to 30 seconds to cover those occasions the phone is on the table and I am intermittently fiddling with it.
    mgbosshogg likes this.
    06-06-2021 08:42 AM
  3. EODK9Trainer's Avatar
    Guess it is time to figure this Bixby out. I so under utilize these smart phones and miss out on so much. I feel I need a teenager to teach me. My first phone back in my 20's was the Bell Atlantic bag phone with 200 free minutes a month. Would only work while plugged in of course.
    06-06-2021 03:15 PM
  4. gomezz's Avatar
    If it is any reassurance I turned 16 recently ... for the fourth time!
    06-06-2021 06:31 PM
  5. gomezz's Avatar
    Rowing back on using Smart Lock for Bluetooth devices after my first shift in the work van yesterday and having to keep unlocking the phone. While working I keep the phone in a belt holster (to avoid it being banged while carrying heavy stuff around) which is not as susceptible to pocket surfing as having it in my pocket while out walking. Maybe another belt holster for my walking trousers is the answer?
    06-08-2021 07:28 AM
  6. gomezz's Avatar
    Have I discovered the secret to kicking Smart Lock back into action? I have been playing with it over the past few days and discovered that on all occasions when Smart Lock didn't kick in when it should to keep the phone unlocked (ie when connected to an authorised Bluetooth device) that pressing the power button to turn the screen off that the phone would then remain unlocked. Couldn't find this workaround suggested anywhere.
    Would be interested to know if I have just been lucky with an extraordinary run of coincidences or if it really is a 100% reliable way of doing it. Note that I have the "Lock instantly with Side key" setting turned on and I figure this triggers the phone to do a proper check / refresh of what should be the current Smart Lock status.
    06-10-2021 03:46 PM
  7. gomezz's Avatar
    And another discovery is the tip that turning off "Lift to wake" in "Motions and gestures" stops my my phone from pocket surfing even when unlocked.
    06-11-2021 06:05 PM
  8. VidJunky's Avatar
    This known. It is similar to when a device without a security lock of any kind is placed in the pocket. Actually you may find that you still run into issues if you are a screen in carrier. If you carry the device screen in, towards your body, you may find that it will still exhibit bad behavior when kept in an unlocked state if you have tap to wake turned on/enabled. Since it is taps/touches that cause the bad behavior in the pocket it could recognize these as a wake up call and still cause issues. If you're a screen out carrier, screen facing away from the body, then those would likely be all the precautions needed.
    ...when Smart Lock didn't kick in when it should to keep the phone unlocked (ie when connected to an authorized Bluetooth device) that pressing the power button to turn the screen off that the phone would then remain unlocked. Couldn't find this workaround suggested anywhere.
    I haven't seen anyone post an issue about it not working when connected to a device, only the location seems to be an issue. I recall looking this up not long after this thread began and seeing articles back as far as 2018. I want to say that I found one from 2015 also but 2018 I can confirm. One would think that with 4 years and 4 or 5 OS updates they would have managed to fix this but it is either not on their radar, they can't fix it but refuse to remove it or not enough people have reported it to make it priority. I can't recall anyone posting here that trusted devices was a problem, not to say that it hasn't been posted anywhere else.
    06-11-2021 07:43 PM
  9. gomezz's Avatar
    Yeh, I am a screen in, USB socket up pocketeer. Would rather risk an accidental double tap than a screen cracking hit from the corner of a table say.
    06-12-2021 08:52 AM
  10. VidJunky's Avatar
    Well at least turn the USB down to keep lint out of it. USBC is a big opening.
    06-12-2021 10:01 AM
  11. gomezz's Avatar
    I keep the USB up precisely to stop it gathering lint from the bottom of the pocket. That it comes out of the pocket in my hand already right way up is a bonus.
    06-12-2021 02:18 PM
36 12
  1. Trusted Place in Smart Lock No Longer Working
    By cyndie1030 in forum Google Pixel 5
    Last Post: 06-08-2021, 09:12 PM
  2. Is "activation locked" iPhone forever a paperweight?
    Last Post: 05-16-2021, 02:37 PM
  3. Auto delete smart switch back ups
    Last Post: 05-16-2021, 11:10 AM
  4. Samsung s10 locked for 1440 minutes
    Last Post: 05-16-2021, 10:21 AM
  5. Why wont my LG tribut Dynasty lock even though i put a pin on it?
    Last Post: 11-30-2018, 07:27 AM
