1. Snareman's Avatar
    I've had this on all of my Samsung phones with multiple wireless chargers. I don't know if it's a phone problem or a charger problem. The phone will charge no problem on the same wireless charger on my desk or in my car one day but the next will get stuck in an endless loop of "wireless charging paused" and it's maddening. Yes, wireless charging and fast wireless charging are enabled. Yes, I've rebooted the phone. I don't understand why it's fine one day and not the next and then back to fine the following day. Anyone know the cause or have a solution? And, is it a phone or charger problem?
    06-23-2021 12:15 PM
  2. B. Diddy's Avatar
    Have you tried the suggestions here? https://appuals.com/fix-wireless-cha...y-note-phones/
    Laura Knotek likes this.
    06-23-2021 12:23 PM
  3. o4liberty's Avatar
    Not a big wireless charging fan I like how fast a wired charger works for me. I use them at my desk for a short while I lay them on the charger but when I leave and get in my car it's plugged in.
    06-23-2021 12:25 PM
  4. Snareman's Avatar
    yes, if I'm in a rush I use wired charging, but casually sitting at my desk at home or in my car I use wireless charging. it's just easier and I don't need a super fast charge in those situations, but I should get a charge.
    06-23-2021 12:33 PM
  5. Snareman's Avatar
    yes. Charger as noted works and then doesn't. Cache cleared. Apps frequently updated. Wireless charging enabled
    06-23-2021 12:36 PM
  6. B. Diddy's Avatar
    Do all of your phones have cases? If so, does this happen with the case off?
    06-23-2021 12:58 PM
  7. Snareman's Avatar
    My phone does have an ultra thin case (the thinnest I could find and not leave a camera hump), but again the odd thing is that it's random. Same charger, same case, works one day and not the next. Same thing all the way back to my S8 and I have updated with new chargers over the years and same problem. I did just download the galaxy app app and tried a few of those things and I'll see if that does anything.
    I've always thought Samsung put out the best phones, but it's these little things about the phone that make me consider getting a Pixel when the new ones come out, hence me trying to figure out if its a phone or charger problem. But the charger is just sitting there static on my desk...
    06-23-2021 01:05 PM
  8. fuzzylumpkin's Avatar
    What brands are your chargers?
    06-23-2021 01:11 PM
  9. B. Diddy's Avatar
    Here's another article: https://wirelessitem.com/solutions-f...arging-paused/. Could it be that vibrations from notifications might be shifting the phone?
    06-23-2021 01:15 PM
  10. Kizzy Catwoman's Avatar
    Wireless charging killed my S10+ battery so I refuse to use it at all now.
    06-23-2021 02:12 PM
  11. o4liberty's Avatar
    How did it kill your battery I always thought wireless was like trickle charging a battery which is good for most batteries.
    06-23-2021 03:58 PM
  12. Kizzy Catwoman's Avatar
    I just know after using wireless charging my battery life went to hell. So I refuse to use it now
    06-23-2021 04:18 PM
  13. fuzzylumpkin's Avatar
    Wireless charging generates more heat in general, which is bad for batteries.
    Still, correlation isn't causation... Could've been any number of things.
    06-23-2021 04:41 PM
  14. Snareman's Avatar
    My home chargers are Choetech and Samsung and my car charger is APPLUS.
    06-24-2021 10:37 AM
  15. Snareman's Avatar
    I don't think it's the vibrations because it happens right when I set the phone down on the charger. I can pick it up and reset it down and it will happen multiple times in a row despite me setting it down in the same way I do all the time when it works. I tried unplugging and replugging in the charger. We'll see if that works long term. And next time it starts acting up I'll try unplugging it at that point and see if it fixes it acutely.
    06-24-2021 10:40 AM
  16. fuzzylumpkin's Avatar
    I'll bet you don't have the problem with the Samsung ones?
    A few months back people started having problems with third party chargers. I've got a ravpower one that won't "fast" wireless charge anymore..
    I'd wager it's to do with that.
    06-24-2021 11:13 AM
  17. Snareman's Avatar
    I actually stopped using the round angled Samsung fast wireless chargers a few years ago because I was having so much trouble with them doing the same thing a few phones ago. That's why I'm wondering if it's a Samsung phone issue as opposed to a charger issue. I'll give one of them a try again how it goes.
    06-24-2021 12:06 PM
  18. Snareman's Avatar
    And, went back to the round Samsung charger tonight and immediately had the problem.
    06-25-2021 01:00 AM
  19. fuzzylumpkin's Avatar
    If it does it on multiple devices with a first party charger, my next guess would be that an app is doing it.
    06-25-2021 05:47 AM
  20. Snareman's Avatar
    I suppose that's a possibility as well. Not likely that I'd be able to figure out which app if it's indeed an app/.
    06-25-2021 12:06 PM
  1. why android system charging connected device via USB is showing contuniuosly ?
    Last Post: 07-06-2021, 09:43 AM
  2. Replies: 2
    Last Post: 06-22-2021, 08:52 PM
  3. Samsung Gear S3 Frontier Charging Issues
    By Girevik in forum Samsung Gear S3
    Last Post: 06-22-2021, 07:47 AM
  4. tab s5e charging icon
    By edgie70 in forum Samsung Galaxy Tab S5e
    Last Post: 06-21-2021, 03:11 PM
  5. The "Your Devices" page of "My Activity" in Google
    Last Post: 06-20-2021, 05:56 PM
