    I noticed a few days ago. there is a short delay when I start to scroll. like the screen didn't respond to my finger and I saw that I just dragging my finger on the screen without anything happening. Only after a sec the screen suddenly responded and start scrolling. This even weirder as this only happens with apps especially Instagram and Google play.
    I tried a few things without success:
    I tried to turn on the screen sensitivity, reboot the phone, clean the cache from a lot of apps.
    I also don't think this is from the screen protector because this problem doesn't happen when I using the setting menu or on the home page.
    Does anyone know how to fix this problem
    07-06-2021 03:28 PM
  2. mustang7757's Avatar
    Have you tried safe mode ?
    Whats your motion smoothness on in settings>display>motion smoothness?
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply
    https://forums.androidcentral.com/sh...d.php?t=409154
    07-06-2021 04:28 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Does this only happen with certain apps? If so, which apps?
    07-06-2021 05:31 PM
  4. Ben xfg's Avatar
    Did you install a new app lately? Maybe try uninstalling apps one by one see if the issue disappears.
    07-06-2021 06:15 PM
  5. mustang7757's Avatar
    Thats what safe mode does , eliminate 3rd party apps all at once , if it doesnt then can Uninstall apps one by one
    07-06-2021 07:53 PM
  6. Ben xfg's Avatar
    Quite right, will keep in mind.
    07-06-2021 08:15 PM
  7. mustang7757's Avatar
    Pretty handy tool safe mode
    07-06-2021 08:46 PM
  8. Jell Lee's Avatar
    would you mind sharing the model device number and the software version?
    you didn't drop your phone or expose to any moisture recently? (in a pool, ocean, rain, dense water vapor etc.)
    if you're in US, you could take it to UBreakIFix and have the display diagnosed to see if the hardware is okay
    07-09-2021 02:51 PM
  1. Gmail notification issue
    By Rumblee1 in forum Samsung Galaxy S21 & S21+ & S21 Ultra
    Last Post: 07-07-2021, 08:16 AM
  2. Google Photos weird storage issue
    Last Post: 07-06-2021, 07:57 PM
  3. Turn off dots when assistant disabled
    Last Post: 07-06-2021, 05:41 PM
  4. Establishing an account here (Android Central)
    By Android Central Question in forum Site Feedback & Help
    Last Post: 07-06-2021, 02:46 PM
  5. Establishing an account here (Android Central)
    Last Post: 07-06-2021, 01:34 PM
