1. Owen Kim's Avatar
    US user here. Samsung phones have this feature that boosts brightness to over 1000 nits when outdoors on a bright day.
    My old S10 did that really well and it makes the screen look amazing even under bright sunlight.
    I just recently noticed that my S21 does not, at all!
    Even outside under the sunlight on a bright day, the screen just maintained its regular maximum brightness, which of course was not enough!
    Restarting the phone did not fix it.
    I had not installed any third party apps that would interfere with phone brightness settings and always had adaptive brightness mode on.
    I am not covering any sensors I am aware of and merely using a film screen protector. (normal brightness adjustment works fine so that is out of the question)
    Not sure what could be the issue here, please share your thoughts, anything would help, thanks!
    09-07-2021 05:57 PM
  2. Laura Knotek's Avatar
    Do you have your display set to natural or vivid?
    mustang7757 likes this.
    09-07-2021 07:10 PM
  3. mustang7757's Avatar
    You leave the brightness in auto ?
    Laura Knotek likes this.
    09-07-2021 09:39 PM
  4. VidJunky's Avatar
    No thoughts to share. I did experience this on a recent sunny vacation. Most days it was near impossible to read anything on the phone and some times it was so washed out that it was difficult to know the screen was even on. I never checked the brightness slider, I just assumed that it was what it was and that was all I got. That's the only time I've had issues and I kind of wish had messed around with it looking back. At the time I was more concerned with getting through the day without charging. That and not letting the phone overheat in the sun.
    09-08-2021 02:58 AM
  5. rjack22's Avatar
    Be sure under display settings that the Adaptive Brightness button is turned on. Thats the only way it will work.
    09-08-2021 05:56 AM
  6. Nyvideo's Avatar
    Isn't adaptive brightness the setting to make it change brightness based on light? That's the only setting I have besides the slider. I've tried that and also never gotten brightness good enough for outside.
    09-08-2021 06:36 AM
  7. Owen Kim's Avatar
    Vivid, so was my s10
    09-08-2021 10:41 PM
  8. Owen Kim's Avatar
    Yes
    09-08-2021 10:41 PM
  9. mustang7757's Avatar
    Yes
    Try safe mode if still happening
    09-08-2021 10:44 PM
  10. Owen Kim's Avatar
    Thanks, will try that
    09-08-2021 11:41 PM
  11. mustang7757's Avatar
    Ok
    09-08-2021 11:46 PM
  1. Why is my Samsung J7 keyboard not popping up?
    Last Post: 09-08-2021, 01:00 PM
  2. Why doesn't my Hangouts typing indicator show when someone is texting me?
    Last Post: 09-08-2021, 12:14 AM
  3. How can I remove the dead space, or bottom padding on my Gboard?
    Last Post: 09-07-2021, 09:51 PM
  4. Replies: 2
    Last Post: 09-07-2021, 02:22 PM
  5. Why does my android phone ring and goes to voice-mail but it says unavailable
    Last Post: 09-07-2021, 01:28 PM
