I'm searching for some good app (possibly free) to have a better Meteo Widget , Desktop Search bar and few more elements, to use with Nova Launcher prime, I'm a newbie so any help is welcome
ty
Printable View
ty
Sorry, are you saying you'd like a good weather widget? If so, try Weawow.
What else do you want your search bar to do that the Google search bar widget doesn't do?
What other elements are you interested in?
Well I'm trying to improve the overall look of my homescreen, the search bar of NOVA is better than the S21 one but still looks quite standard then a good clock and calendar
Download KWGT on Google play store. https://play.google.com/store/apps/d....kustom.widget
My favorite clock widget is DIGI Clock Widget, because you can use any TTF font with it. I like the Google Calendar widget, so I haven't looked for another one, but I've read a lot of good things about Business Calendar 2.
Ok tyvm
I'm not happy at all about Weather Widget and desktop search bar (and few more things) any help to improve them ?
Attachment 338247
