1. shobuddy's Avatar
    've noticed that while I'm connected to WIFI, the 5G or LTE symbol will sometimes popup in the status bar and then go away. You can see this in the screenshots below where the top photo shows LTE while connected to WIFI and in the photo below, its gone, which I think is normal. I'm just curious as to what it means when the LTE or 5G symbols pops up while connected to WIFI.
    10-30-2021 10:50 AM
  2. mustang7757's Avatar
    Could be do to poor wifi , but I get that on my Samsung devices also or a service that needs Mobile data
    shobuddy likes this.
    10-30-2021 11:17 AM
  3. puch96's Avatar
    To me this is a bug that no one has really pushed Samsung to fix (or at least no one cares as it does not seem to affect functionality.
    As mustang said, I've also notice this on Samsung phones often (as my wife has the Note series)....
    Or, maybe Samsung is doing this for some purpose that I can not understand....
    mustang7757 likes this.
    11-04-2021 08:48 AM
  4. mustang7757's Avatar
    What I learn , is there a app that's using mobile data for something like location , quick fix is go to recent apps and clear all and that Icon should go away , usually apps are banking apps that can cause this to use mobile data in background
    11-04-2021 02:03 PM
  5. djousma's Avatar
    This is true. I just moved into a fringe coverage area. I have great internet, and expected to be able to live with everything on wifi. Well, certain apps still require cell network service. A couple that I noticed Google messages for one, specifically when doing group text. there appears to be a bug. first text will send, but subsequent ones would just time out. put the phone into airplane mode and out again, and the text would send.
    Another app that requires mobile network is PINGID. my employer uses it to authenticate remote access into the network. on cell network, i'll just get a prompt to ack the logon, on wifi, i am required to actually key in the 6 digit passcode.
    In the end, I ended up buying a VZW network extender. Solved all the problems with google messages, and made PINGID work as intended, until of course my internet has an outage.
    11-09-2021 12:24 PM
  6. mustang7757's Avatar
    You can turn off data background in each app to prevent this just long press the app then tap info>tap mobile data and turn off for background
    11-09-2021 12:30 PM
  1. WiFi Issue
    By YankInDaSouth in forum Google Pixel 6 & Pixel 6 Pro
    Last Post: 11-01-2021, 09:01 AM
  2. How to turn off 5g?
    By david61983 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 10-31-2021, 09:48 PM
  3. Why no 2 button navigation on Pixel 6 Pro?
    By Davidoo in forum Android 12
    Last Post: 10-31-2021, 07:01 AM
  4. How so i exit the stupid tabs on my dadgum phone?
    Last Post: 10-30-2021, 02:17 AM
