Galaxy S21 4g/5g Connection Issues
I have a galaxy s21 thats ~ a year old.
I am having issues with my 4g/5g connection. The Phone says i have connection but i dont always have internet.
The only way i have found to fix this issue is to either remove cache or go into settings->connections->mobile networks->network operators-> and choose my own network operator manually (this is a temp fix that i have to keep refreshing a few times a day)
I am on verizon.
Any ideas? Could the sim card be going bad?
thanks!
Re: Galaxy S21 4g/5g Connection Issues
Same issue on TMobile I just shut off 5g and all is good just no use of 5 g. I have a iPhone 13 and no issues at all.
happens here, too (T-Mobile)...only on 5G
If this was happening just recently here a article
Looks like yesterday it happened.
https://www.theverge.com/2021/11/29/...l-cant-connect
I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply
https://forums.androidcentral.com/as...community.html
I too get this issue at times when roaming around in various cities. I am with tmobile and find that the 5G takes a few minutes in order to establish a good connection.. or.. a connection that works. All bars are full, yet there are times where I cannot browse or do things online.
This has been an on going issue, and not just recently, as reported in that link. This is my first 5G phone, so not sure if it is a phone or carrier issue, as i was with AT&T prior, but never had mobile data connection issue, but then again I wasn't on 5G then.
Not sure if it is worth checking with T-mobile?
have you contacted Verizon?
try disabling wifi calling. I had connection issues until I disabled wifi calling. No problems since.
Originally Posted by
me just saying try disabling wifi calling. I had connection issues until I disabled wifi calling. No problems since.
Good to know. What carrier are you with?
Yep I wouldn't turn on wifi calling unless I actually needed it.
