Strange downloading notification on S21ULTRA
Recently when I startup my s21ultra a downloading symbol appears in the notification bar. I pull down the notification bar and it says "hidden content" and shows the secure folder symbol. I tap on it and it takes me to the pin login page for secure folder but I can't find out what app is receiving the download. Any ideas what it might be? Maybe time for a factory data reset?
Re: Strange downloading notification on S21ULTRA
Do you have anything in the Secure Folder to begin with?
Originally Posted by
B. Diddy Do you have anything in the Secure Folder to begin with?
In the notification it says "speech services by google." The downloading symbol keeps going and going. The apps in my secure folder are gallery, calendar, my files, contacts, camera, Samsung internet, and Samsung notes.
I was finally able to turn off the notification. I long-pressed the notification, tapped settings, turned off notification.
B. Diddy Sure sounds like the same issue. Thank you for posting that.
GoNavy79 Sure sounds like the same issue. Thank you for posting that.
Do you use secure folder?
mustang7757 Do you use secure folder?
So far, I have only used it to store photos of my covid card.
GoNavy79 So far, I have only used it to store photos of my covid card.
I dont use it myself in long time but i opened one time checking something for a member to help and never used it again it try downloading something so i cleared it data and force stop and didn't open again lol
GoNavy79 Recently when I startup my s21ultra a downloading symbol appears in the notification bar. I pull down the notification bar and it says "hidden content" and shows the secure folder symbol. I tap on it and it takes me to the pin login page for secure folder but I can't find out what app is receiving the download. Any ideas what it might be? Maybe time for a factory data reset?
I have had the same thing happen a few times on my Note 20 Ultra. I'm trying to figure out what the issue is behind it. I don't have auto updates turned on for anything on my phone. Can't figure out what it could be in the secure folder app that would be downloading. All that I have placed in there is some pictures. No reason why anything should be downloading in the folder at all. Would be thrilled if somebody has a solution so i can figure what's going on. Also when I tapped the notification it brought me to secure folder and asked me to enter my pin. After that the download stopped.
