Is there a setting I can undo on my Samsung galaxy FE S21. I find it annoying to keep increasing the volume after a while.
In settings>sounds>do you have media limit on ?I tried those steps ... the issue is still there
Ok hopefully thats all it wasOmg yes ... under volume, the cursor was set at 80%, the exact limit it tends to go back to. I moved the cursor to the far right and hope it fixes it
I thank you profusely because it was an annoying device quirk. I do hope that one day when you face something annoying, that it is fixed through the kindness of a stranger just like how you helped me
Can you try safe mode ? Maybe some 3rd party app causing thisThe same issue persists. Media volume limit was set to off. Volume was at 80%, I moved cursor to max right side. I think I'll take it to android service center. Its still covered by warranty
Usually delete one or 2 at a time and test , if you have lot of apps not going be easyTried safe mode. Played multiple loud music videos, it doesn't go down. Can I find the culprit app?
