1. EODK9Trainer's Avatar
    Three times total over a period of two days. The third time, early this am, took a long time to restart and I had to keep pushing the on/off button to finally get it moving. All 3 times Waze was on but I was on a cross country drive so Waze was on each day of my drive. I keep it updated as soon as I see one is out and I never scheduled it to download except in the middle of the night. Thoughts?
    06-28-2022 04:03 PM
  2. B. Diddy's Avatar
    Was it pretty warm? Were you using it for nav on a dash mount? That often leads to overheating, which can force a shutdown. If you do use it for nav, it's best to use one of those AC vent mounts, so that cool air is always blowing on it.
    SpookDroid likes this.
    06-28-2022 05:58 PM
  3. mustang7757's Avatar
    Do you have auto restart on?
    Do you use it for navigation?
    06-28-2022 08:25 PM
  4. RoseBud68's Avatar
    Bueller....Bueller....Bueller
    06-28-2022 09:10 PM
  5. B. Diddy's Avatar
    The Smoot Act? The Hawley-Smoot Act?
    J Dubbs likes this.
    06-28-2022 11:53 PM
  6. EODK9Trainer's Avatar
    While in AZ and NM it was warm but once past that I actually had pleasant weather. My phone sits in a holder that sits in my cup holder which basically sits in front of one of my vents meaning it gets ac directly. I had Waze on the entire time. I believe it did this at least once on our trip out west a few weeks ago as well and 3 times on my trip back.
    06-29-2022 05:05 AM
  7. EODK9Trainer's Avatar
    Not sure what auto restart is but this has not happened before this trip.
    06-29-2022 05:07 AM
  8. B. Diddy's Avatar
    If it happens again, check to see how warm the phone feels anyway.
    This is the Auto Restart feature the mustang7757 was referring to: http://www.samsung.com/ph/support/mo...galaxy-device/
    mustang7757 and J Dubbs like this.
    06-29-2022 10:29 AM
  9. mustang7757's Avatar
    It should be in device care settings
    EODK9Trainer likes this.
    06-29-2022 10:30 AM
  10. mustang7757's Avatar
    Download Nice Catch from Galaxy store also , might give indication whats restarting for
    06-29-2022 11:03 AM
  11. SpookDroid's Avatar
    I would imagine this would be temp-related as others have suggested, but just in case, also check the power button (if it's stuck somehow, it can prompt a soft reset after being pressed for a long period of time) and the USB cable you're using (if any) as these can also trigger power actions if faulty/damaged pins.
    06-29-2022 03:13 PM
  12. EODK9Trainer's Avatar
    Play Store recognized Nice Catch but I saw no app by that name listed anywhere.
    06-30-2022 01:57 PM
  13. EODK9Trainer's Avatar
    I completely forgot that the last time it did this was around 4am as I was driving through the mountains of WV on I-64. In the 50's outside and I did not have the heat on. Not sure heat could have caused this one at least. Even the other 2 times were in a vehicle with the AC turned down low and no sun hitting the phone. I'm sure there is an answer but not sure overheating is the issue.
    06-30-2022 02:03 PM
  14. mustang7757's Avatar
    https://apps.samsung.com/appquery/ap....app.goodcatch
    EODK9Trainer and Laura Knotek like this.
    06-30-2022 02:04 PM
  15. B. Diddy's Avatar
    This might also be related to multiple posts we're seeing about Samsung phones (I think all running One UI 4.1) randomly rebooting lately. I wonder if a recent update by Samsung and/or Google might have introduced some bugginess. Send feedback to both Samsung and Google about this.
    J Dubbs likes this.
    06-30-2022 02:34 PM
  16. lyingfromyou's Avatar
    That last update was pretty chunky..
    B. Diddy likes this.
    07-01-2022 10:35 AM
  17. EODK9Trainer's Avatar
    Got it. I was doing the Play Store which was not showing me this one. Forgetting I have the Galaxy Store I found it and the app.
    mustang7757 likes this.
    07-01-2022 03:22 PM
  18. jbjtkbw007's Avatar
    What was the outcome of this? I'm curious to see if it was resolved.
    J Dubbs likes this.
    07-19-2022 08:48 AM
  1. Replies: 3
    Last Post: 06-28-2022, 06:18 PM
  2. 'phone's not registered on a network...'
    By kgilbertsen in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 06-28-2022, 02:15 PM
  3. Venmo app won't load on my phone
    By rscottea in forum Android Apps
    Last Post: 06-28-2022, 10:56 AM
  4. how do i cancel my accounts
    By Android Central Question in forum Site Feedback & Help
    Last Post: 06-28-2022, 10:55 AM
  5. how do i cancel my accounts
    Last Post: 06-28-2022, 09:56 AM
